pine board for ceiling - diagonally
Discussion in 'Remodel Forum & Blog' started by cobrastring, Jul 26, 2008.
  1. cobrastring
    cobrastring New Member
    Jul 23, 2008
    would like some info regarding the placing of this type of ceiling -- with 5 1/2"
    pine boards for my 8 x 12 ceiling -- such as starting point, staining, type of nails etc -- can someone give me a little expert advice -- i am not a carpenter.
    thanks,
    cobrastring
  2. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    You would want to use tongue-and-groove boards, and you would nail on an angle at the base of the tongue so the next board would cover the nailhead.
    All the sanding-and-staining and sanding-and-sealing work should be done before any boards go up, and you will need a way to make very clean cuts during installation.
    You will need nailing blocks between the ceiling joists along the walls so you will be able to nail the ends of all boards ...
    Those are some things that come to mind at the moment.
  4. statjunk
    statjunk DIY Senior Member
    Jun 28, 2007
    You'll also want to check the ceiling joists for sags and make any necessary flattening corrections before you start. A six foot level is great for this kind of thing.
    Tom
  5. cobrastring
    Jul 23, 2008
    diagonal ceiling -- pine boards
    thanks guys for this -- i will give it a try
    cobrastring
Similar Threads: pine board
Remodel Forum & Blog laminated pine panels Nov 23, 2009
Remodel Forum & Blog Pine Floor Install Oct 13, 2009
Remodel Forum & Blog Looking For Something More Attractive And Durable That Standard Baseboard. Sunday at 2:24 PM
Remodel Forum & Blog 15 minute thermal barrier at top of 2 inch xps foam boards. Oct 23, 2014
Remodel Forum & Blog Backer board for prefab shower Aug 28, 2014
