PH Levels and Testing Meters
Discussion in 'Hydroponics, Gardening, Greenhouse' started by hygron, Jul 7, 2013.
  1. hygron
    hygron Member
    Jan 29, 2010
    Grrenhouse proprietor, Hydroponic/Fertigation Syst
    Hell Hole Swamp
    In this thread we will cover the level of PH in your reservoir, and in your soil.
    PH for Hydroponics solutions are 5.8-6.1 (slightly acidic) This margin of error is fine and should never cause you any issues. Too high or too Low a PH level and you can lock out essential nutrients from the plant, potentially causing less yield, making plant susceptible to disease, and even death :(
    When using "fertigation" methods, (delivering nutrient solution to a Soil bed), desired PH level is between 6.5 - 7.0 (a bit acidic to neutral).
    You can test solution or soil runoff with a simjple garden test kit.
    Or; It is recommended to get a PH pen or meter , a TDS/EC pen or meter, and a waterproof temp. gauge or meter.
    We will be posting images of some PH, TDS, EC, and Multimeters we have used over the years. We use Milwaukee Meters at our farm.
