PEX with Baseboard Heat????
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by skull141994, Sep 29, 2007.
  1. skull141994
    skull141994 New Member
    Sep 29, 2007
    I'm looking at moving a baseboard register to make a door way to the adjoining room. Although it could be replumbed with copper access is limited and I thought it would be MUCH easier to use PEX instead.
    I can get a Zurn 3/4" crimp tool and the local home stores have the tubing and fittings. I'm just not sure if this is a good approach.
    Questions:
    1. Can you use PEX with baseboard heat?
    2. If answer to one is yes, can the PEX be the same as the material used in a water supply as long as its rated to 80psi @ 200F or should the tubing be of the radiant floor kind?
    3. How important is the oxygen barrier? Would I need tubing with an oxygen barrier to keep the boiler components on the boiler from rusting out?
    Love this forum...all input is appreciated.
  2. hj
    pex
    1. Yes.
    2. This is answered by #3.
    3. Heating pipes do need the oxygen barrier to prevent assimilation of oxygen which will cause premature failure of the components, since they are designed for a closed system, with the oxygen leached out of it.
  4. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Sorry to say but Im not big fan of plastic water piping and would do it in
    copper.For baseboard heating.
  5. Livin4Real
    Livin4Real New Member
    Sep 7, 2007
    Flight Operations and DIY'er
    Indianapolis, IN
    If you do decide to go with pex use another brand besides zurn. They have a class-action lawsuit against them right now for fittings breaking.
  6. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    what brand would be best?
  7. Livin4Real
    Sep 7, 2007
    Indianapolis, IN
    Vanguard is the best according to most installers I've talked with, but it's also 3x the price of the others. I'm using vanguards manabloc but using nibco fittings and tubing (durapex) found at m enards. I'm new to pex as well, so hopefully someone else with more pex experience will chime in.
  8. Livin4Real
    Sep 7, 2007
    Indianapolis, IN
  9. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Stll dont like it
    It dosnt mater as we only allowed copper behind closed walls.
  10. skull141994
    Sep 29, 2007
    Thanks to all for the replies. I'll need to see if I can find another supplier or just use copper.
    I didn't realize zurn was having problems. Lucky me I just put in a couple of their fittings :eek:
Similar Threads: Baseboard Heat
Plumbing Forum, Professional & DIY Advice Relocating Baseboard Hotwater Heater Oct 13, 2014
Plumbing Forum, Professional & DIY Advice put ball valve(s) on each water heating baseboard branch? Oct 2, 2014
Plumbing Forum, Professional & DIY Advice slow leak on CI baseboard (water heating) air pressure testing Sep 23, 2014
Plumbing Forum, Professional & DIY Advice Threaded brass fittings ok in baseboard heating system? Jun 7, 2013
Plumbing Forum, Professional & DIY Advice Adding baseboard heating to my current system. Nov 12, 2012
