Pex vs copper. Which stands up better to cold?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by pitteach, Jul 12, 2010.
  1. pitteach
    pitteach New Member
    Jan 14, 2008
    Hamburg, NY
    I am re-plumbing a ground floor bathroom with 2 walls that are shared with the garage. I do need to run 1/2" h/c supplies through these walls and I am not sure if I should use pex or copper. The walls are 2 x 6 with fiberglass insulation. The supplies will be wrapped in foam jackets and foam where they penetrate the studs. I do not anticipate a freezing condition, but I still want to use the material that will hold up best during temperature fluctuations. Access is not an issue and either copper or pex will be fairly easy to work with.
    The bathroom was previously done in cpvc which burst because the house sat for a while unheated during the winter.
    So the question is... which to use?
  2. North Jersey
    North Jersey New Member
    Jan 1, 2009
    Without a doubt, PEX. PEX can expand many times its original size without bursting. Even if the copper itself does not split, your plumbing solder will crack. Last winter our basement underwent water damage when the sweated joints failed during exceptionally cold conditions. Your fittings will still be vulnerable, but you'll be much better protected with PEX than with copper.
  4. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    Copper with heat trace and insulation.
  5. North Jersey
    Jan 1, 2009
    I imagine while the house is occupied the plumbing in this bathroom would not experience freezing temperatues. If the house is going to be unoccupied, wouldn't an oil-filled electric baseboard heater with a thermostat work out a little better than heat tape? I just feel uncomfortable about having the tape inside the wall. Are my fears unfounded? If the power went out, wouldn't PEX be a little better than copper?
  6. Doherty Plumbing
    Jun 22, 2009
    Penticton, BC
    If the water freezes the pex will still split and rupture. I've seen it MANY times.
    The heat trace should be 100% safe inside the wall.
  7. Terry
    Aug 17, 2004
    The question was which pipe would be better if the power went out.
    PEX
    Copper always splts when the power goes out.
    PEX may split.
  8. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    It depends on the Pex used and several other factors.
    PEX AL PEX is not freeze resistant at all!
    PEX will normally expand and not split but the distance between brass fittings if between 2" and 7" apart PEX may split.
    This was the results of a study done several years ago in a nut shell...
  9. North Jersey
    Jan 1, 2009
    I believe the Uponor Aquapex is particularly freeze resistant since it's designed to be expanded over the fittings. It's a lot more resilient than some other stuff I tried.
  10. Doherty Plumbing
    Jun 22, 2009
    Penticton, BC
    Try and expand the pipe when it's freezing and not sitting at room temperature.
  11. Redwood
    Dec 15, 2007
    Service Plumber
    No!
    Uponor PEX did experience splits in the test when fittings were 2-7" apart.
  12. North Jersey
    Jan 1, 2009
    That's why I keep all my fittings eight inches apart. :)
Similar Threads: copper stands
Plumbing Forum, Professional & DIY Advice Bending 3/8" chromed copper supply pipe to toilet Feb 20, 2017
Plumbing Forum, Professional & DIY Advice 3 Inch copper waste pipe cracked and leaking. Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Replacing Copper Water Supply Line with PEX? Feb 2, 2017
Plumbing Forum, Professional & DIY Advice The beginning of a copper repipe Jan 29, 2017
Plumbing Forum, Professional & DIY Advice 3/4" threaded = brass or copper Jan 27, 2017
