Pex to Copper
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by danaelk, Oct 29, 2009.
  1. danaelk
    danaelk DIY Junior Member
    Oct 29, 2009
    Minneapolis, MN
    I'm roughing in for some hw baseboard. I have been using pex (w/O2 barrier) and it's been working great as this is a remodel. When roughing in stud spaces, can I install a copper stub out elbow that is made for a pex conn on one end and a sweat conn on the other. After i've crimped on my pex, and the wall is rocked, I am concerned that my sweating on the fin tube will heat up and damage the pex.
    In other words, what are the best fittings to use for this application.
    Thanks in advance for your input.
  2. rmelo99
    rmelo99 Network Engineer
    Jul 7, 2006
    Network Engineer
    You need to have more copper between the pex and where u are sweating. Either all sweating is done before the crimping or you must have something like 18" + of copper.
    I'm sure the pros will know more specific numbers, but that's what I did when I ran mine. Just keep the pex as far a distance away from where you arw sweating.
    I know they sell copper stub outs for sink stops that are nothing more than a little L pex crimp and then turn out the wall. I would imagine Unless you are putting a compression stop on there then there is very little to sweat to.
  4. danaelk
    Oct 29, 2009
    Minneapolis, MN
    Makes sense, Thank You
  5. D'Brie
    D'Brie Apprentice Plumber
    Oct 20, 2008
    Apprentice Plumber
    NW Washington State
    PM to you...
  6. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    Call your local plumbing whole-saler and see what they have. They may have exactly what you're looking for. Us plumbers use something similar quite a bit with bathroom rough-ins.
    I call them pex bullets (Don't know the technical name for them) but what they are is a prefabbed copper 90 that have a pex crimp fitting on one end. They can also come with a backing plate on them so you can screw them to a stud.
    I'm not sure what size you are looking for but I know they make them in 1/2". But if you're looking for 3/4" they may be tough to find....
  7. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Uponor makes female and street baseboard ells in 3/4 and 5/8
Similar Threads: Copper
Plumbing Forum, Professional & DIY Advice Bending 3/8" chromed copper supply pipe to toilet Today at 8:27 AM
Plumbing Forum, Professional & DIY Advice 3 Inch copper waste pipe cracked and leaking. Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Replacing Copper Water Supply Line with PEX? Feb 2, 2017
Plumbing Forum, Professional & DIY Advice The beginning of a copper repipe Jan 29, 2017
Plumbing Forum, Professional & DIY Advice 3/4" threaded = brass or copper Jan 27, 2017
