PEX stubout to fixtures – How to?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by ThomasE, Jul 16, 2009.
  1. ThomasE
    ThomasE New Member
    Jul 16, 2009
    Hello,
    I’m replumbing my house to PEX and searched previous threads on how to stub out from PEX to fixtures. I seem to read that it is possible to run the PEX all the way to the stop valve and that there are either compression stops that can be used directly with PEX (a Brasscraft using SS ferrule insert was mentioned). Or perhaps valves that connect PEX directly to the fixture like this one (?):
    [​IMG]
    So I like bringing the PEX all the way to the stop valve, because seems like it would eliminate all in wall connections. However, I cannot envision how the PEX coming out of the wall is secured and/or how the stop valves are secured.
    Any info greatly appreciated.
  2. rmelo99
    rmelo99 Network Engineer
    Jul 7, 2006
    Network Engineer
  4. ThomasE
    ThomasE New Member
    Jul 16, 2009
    Great! Thanks for the advice. That seems like what I need.
    Now, if they could combine the two (so that, say, the chrome sleeve threads onto the bend support) that would be even better. Otherwise, won't the chrome be still a bit "floppy" and perhaps not quite perpendicular since it is only supported by the rigidity of the PEX? (I'm thinking of WC supply).
Similar Threads: stubout fixtures
Plumbing Forum, Professional & DIY Advice Product suggestion: Stubout for PEX Repipe into Finished Walls Oct 18, 2016
Plumbing Forum, Professional & DIY Advice Pull-stop-box PEX stubout: Is it any good ? Jan 22, 2016
Plumbing Forum, Professional & DIY Advice Need help with stubout for lavatory...can I relocate? May 14, 2014
Plumbing Forum, Professional & DIY Advice Common P trap to stubout alignment issue May 19, 2011
Plumbing Forum, Professional & DIY Advice PEX stubout for replumb Dec 18, 2010
