PEX quick disconnect or crimp?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by ofblong, Jan 18, 2009.
  1. ofblong
    ofblong Journeyman Industrial Mechanic, Electrical Apprent
    Jan 17, 2009
    Michigan
    Right now I have both crimp fittings and quick disconnect fittings on the PEX in my house. The only differences I have found so far...
    Crimp
    1. Requires a tool to install
    2. made of copper
    3. Costs 1/2 as much as copper fittings
    Quick Disconnect
    1. No tools required to install
    2. Plastic
    3. costs same as copper fittings
    Other than that I am wonder what other differences there are. I have found that I like the quick disconnect better than the crimp do to the fact you can swivel them (just like air fittings) to screw them into whatever your screwing them into.
    Just so you know I am not a plumber. I am an Journeyman industrial Mechanic, electrical apprentice. But thats why I am asking this ? because I am not a plumber... I dont do plumbing for a living and I dont install plumbing. I will help friends/family out when asked and will do it for my own needs of my house but thats as far as I go.
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
  4. rmelo99
    rmelo99 Network Engineer
    Jul 7, 2006
    Network Engineer
  5. Redwood
    Dec 15, 2007
    Service Plumber
    It's funny They used to be so good when Wirsbo/Uphonor held the Patent Rights. Then the Patent Rights ran out they went to the Expansion system and the "Bad" Propaganda started...
    Want to see something...Go out and look under the hood of your car...
    Do you see any ssc clamps? I wonder why they work so well in the automotive world with the temperature extremes and vibrations cars experience? Surely the temperature controlled, static location life is just to tough for them.
  6. rmelo99
    Jul 7, 2006
    Network Engineer
    Yes, my first set of SSC clamps when I started the project were Uponor/Wirsbo, then they "stopped" making them. I still used their tubing but had to finish with Zurn/Watts SSCs
  7. Redwood
    Dec 15, 2007
    Service Plumber
    Do you have Zurn fittings? Or, just the crimp rings?
    I never used the Zurn fittings. I thought they were junk and I guess I was right cause they had problems.
  8. rmelo99
    Jul 7, 2006
    Network Engineer
    Not saying :-( , i'll let you guess.
  9. Redwood
    Dec 15, 2007
    Service Plumber
    Where in CT are you?
  10. rmelo99
    Jul 7, 2006
    Network Engineer
    I'm in Bridgeport
  11. Redwood
    Dec 15, 2007
    Service Plumber
    Oh okay... I was just curious... In Middlesex area myself.
    Yea, the zurn brass fittings have a habit of breaking.
Similar Threads: quick disconnect
Plumbing Forum, Professional & DIY Advice Quick disconnects on Fixtures and PEX Jan 20, 2016
Plumbing Forum, Professional & DIY Advice Disconnecting a Glacier Bay Quick Connect and/or water flow issues. Apr 28, 2013
Plumbing Forum, Professional & DIY Advice I can't find a quick disconnect gas connector Oct 29, 2012
Plumbing Forum, Professional & DIY Advice 20 lb propane quick disconnect adapter Nov 5, 2008
Plumbing Forum, Professional & DIY Advice Pex Quick-Disconnects May 28, 2008
