Pex or copper for return
Discussion in 'HVAC Heating & Cooling' started by JOE1934, Jun 9, 2007.
  1. JOE1934
    JOE1934 New Member
    Jun 3, 2007
    New York
    Which would be better, PEX or copper in the return of the slant-fin Base Board . I'm concerned about securing the PEX inside the S/F BB.Where or how do you secure it inside the BB.
  2. jadnashua
    For the same size pipe/tubing, pex has a smaller inside diameter, so take that into consideration.
  4. JOE1934
    JOE1934 New Member
    Jun 3, 2007
    New York
    Securing in S/F base board
    I am wondering about securing it in the base board. If I use PEX will the expansion (PEX suppose to expand when hot), be to much inside the S/F BB
  5. jadnashua
    I don't know the relative expansion rates for copper and pex, but they both expand when heated. As to running pex along the baseboard, two thing: will sunlight strike it (not good for extended periods), and will it be protected from potential knocks and cuts (copper will dent, but is much harder to cut)? I'd lean towards copper for the increased flow, impact resistance, and UV tolerance. Pex would be cheaper and require fewer joints.
Similar Threads: copper return
HVAC Heating & Cooling Torque wrench for copper lines? Aug 19, 2016
HVAC Heating & Cooling My house has all the copper baseboard going in a weird double loop. Mar 15, 2014
HVAC Heating & Cooling copper strapping hangers touching aluminum ducts Jun 21, 2012
HVAC Heating & Cooling Life expectancy of copper and black iron pipe Jun 17, 2011
HVAC Heating & Cooling Flexible copper in hydronic heating systems Aug 29, 2010
