PEX near electric water heater
Edwardh1
South Carolina
Maybe old question, my plumber installed PEX close to my new AO smith electric tank heater. Right up to the short nipples that come out the top of the heater.
Is that OK? I read this in a 2010 california building code (maybe a draft version):
604.11.2 Water Heater Connections. [Not Adopted by BSC, HCD, DSA/SS, DHS, AGR & OSHPD 1, 2, 3 & 4] PEX tubing shall not be installed within the first eighteen (18) inches (457mm) of piping connected to a water heater.
That sounds right. We don't install PEX to the water heater for that reason. We have at least 18" of something metalic between the PEX and the water heater.
Rayh78
Colonial Heights, Virginia
I can understand it for a gas water heater, because of the heat from the flue.
But with electric the pex is not going to get any hotter if it is 18" away.
FWIW, most PEX has an upper safe operating temperature limit of 180-degrees. The T&P safety valve on the WH opens at around 205-degrees. It's prudent to keep the plastic tubing away from the top of the WH where it can cool a little from radiant conduction should something go amiss.
Robert-SC
Columbia, South Carolina
Can the 18" copper be ran down beside the hotwater heater using a copper elbow? Is the length of the copper important and not its location?
