Pex Insulation
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by santanaf, Oct 25, 2006.
  1. santanaf
    santanaf New Member
    Oct 8, 2006
    I am running some PEX from my basement to my attic to feed a hydro-air coil in my attic air handler. I would like to insulat the PEX as best as possible in the wall and in the attic space. The normal R2.2 foam pipe insulation seems a little weak. What sort of insulation do others like to use?
Similar Threads: Insulation
Plumbing Forum, Professional & DIY Advice Pipes above or below insulation with unusual insulated slab on grade Jan 31, 2017
Plumbing Forum, Professional & DIY Advice pipe insulation for cold water Jan 14, 2012
Plumbing Forum, Professional & DIY Advice Insulation ok? Oct 7, 2011
Plumbing Forum, Professional & DIY Advice Pipe Insulation Apr 28, 2011
Plumbing Forum, Professional & DIY Advice Shower Steam Generator Pipe in Contact with "Pink" Insulation Jan 30, 2011
