pex insulation
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by peltaz, Oct 15, 2009.
  1. peltaz
    peltaz New Member
    Nov 18, 2008
    I haven't really thought of this but just read about it on this forum. I have Wirsbo Pex running through an uninsulated crawlspace in southern AZ. Is it worth insulating the supply lines running through there?
  2. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    Do you experience freezing conditions? In S. Florida we don't so supply lines are rarely insulated.
  4. peltaz
    peltaz New Member
    Nov 18, 2008
    We get a couple of freezing days a year. Sometimes in the 20s for a few hours.
  5. FloridaOrange
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    You are likely OK. If your lines are not exposed to the elements (I mean outside of the underneath of your structure) they are likely alright.
    If you are concerned however, insulation is cheap and not too dificult to install.
  6. peltaz
    peltaz New Member
    Nov 18, 2008
    Thanks. Something to think about.
Similar Threads: insulation
Plumbing Forum, Professional & DIY Advice Pipes above or below insulation with unusual insulated slab on grade Jan 31, 2017
Plumbing Forum, Professional & DIY Advice pipe insulation for cold water Jan 14, 2012
Plumbing Forum, Professional & DIY Advice Insulation ok? Oct 7, 2011
Plumbing Forum, Professional & DIY Advice Pipe Insulation Apr 28, 2011
Plumbing Forum, Professional & DIY Advice Shower Steam Generator Pipe in Contact with "Pink" Insulation Jan 30, 2011
