PEX for shower plumbing
Discussion in 'Shower & Bathtub Forum & Blog' started by tlt3900, Apr 23, 2013.
  1. tlt3900
    tlt3900 New Member
    Apr 23, 2012
    Cypress Texas
    Hi,
    I've read in a couple of places that PEX was not recommended for the drop from a shower valve to the tub spout and should not be used from the valve to the shower head. I'm not sure i understand why.
    I am hoping to use PEX in my shower from the pressure balance valve to the diverter and then from the diverter to each the rain shower head, hand wand, and the body spray pressure balancing loop.
    Are there any opinions one way or the other on this? Thanks for the advice and help
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    The inside diameter of PEX is smaller than the equivalent copper pipe size. Running PEX to a tub spout can cause a restriction which forces water out of the shower head regardless of the position of the diverter.
    It is good practice in many situations to install PEX in the next larger pipe size than one would normally install when using copper.
  4. tlt3900
    tlt3900 New Member
    Apr 23, 2012
    Cypress Texas
    Thank you cacher_chick, i understand now about the tub spout. I was planning on using 3/4 inch pex with a 3/4 inch pex to 1/2 inch NPT connection to the valve. Thanks again for the help. I see from your avatar that you are from Wisconsin. I live now in Houston but grew up in Rockford Illinois and lived in Menasha for awhile.
Similar Threads: shower plumbing
Shower & Bathtub Forum & Blog Two Shower Heads, No tub. Simple Plumbing ??? Wednesday at 12:50 PM
Shower & Bathtub Forum & Blog Shower remodel plumbing dilemma Dec 8, 2015
Shower & Bathtub Forum & Blog Finish Work Shower Plumbing Fixtures Aug 15, 2015
Shower & Bathtub Forum & Blog Custom Shower Plumbing Rough-In Advice Needed Jul 8, 2015
Shower & Bathtub Forum & Blog Help with Large Master Shower plumbing Mar 17, 2015
