PEX Fittings
Cayenne
Vancouver, BC
Can someone tell me which is the better or certified system to use? crimping (SS Surloc rings) or clamping (black copper ring)
Are both methods certified fo use in Canadian homes? Canadian Plumbing Code or CSA.
Thanks
Jerome2877
Vancouver Island , BC
First, its the other way around, the copper rings are crimp and the ss rings are clamps. The copper crimps are by far the most popular method. I can't comment on the ss clamps as I have never used them, but I beleive they are CSA aproved.
Ballvalve
northfork, california
go to PEX supply on line and look around. I like the SS cinch clamps, they get into much tighter spaces than others. Never had a leak. Dont need to screw with a go-nogo gauge. Easy to remove, and can build the entire system LOOSE before crimping them.
Just to broaden the horizon...Uphonor has been selling their expansion pex system for decades and it also works well. No crimp rings, larger diameter through the fitting, and the most flexible pex that bends into the smallest diameter and is repairable if you kink it during install without cutting the section out and installing a fitting (how's that for a run-on sentence!). The expander tool is not inexpensive, and unless you get a powered one, your hand and arm will get a good workout (you might be able to rent one or buy it and resell). It's harder to get the tool into small spaces, but you do have a few seconds to insert the fitting before the tubing collapses to make the seal, so usually you can plan ahead and not have problems. Pex has a memory and always wants to return to its original shape. By expanding it, when it tightens onto the fitting, it will always be trying to make it tighter. A crimp system is working against its natural tendency. On a crimp system, the fitting must be small enough to slide into the tubing. On an expansion system, the fitting will not fit in until you've stretched (expanded) the tubing. Then you put the fitting in, and it collapses to make the seal. Really neat, clean, and reliable.
Pex is manufactuered using three methods -A, -B, and -C and -A tends to be a bit more expensive (and flexible). As with anything, quality control is critical, and there have been issues with any. Pick a good manufacturer and you should be fine with any type.
You "cinch" the rings so they "clamp" onto the pipe. Typically, what we refer to as "clamps" are the gear type hose clamps. And to complicate it further, Oetiker calls them "crimp clamps".
Uponor uses expansion and their own rings that slide over and shrink.
This expandes the pipe and collar.
Ballvalve
Yes, you can use SS clamps over uphonor, done miles of it. Get the right fittings, obviously. The ss crimps pretty much imitate their silly expansion sytstem [designed so they could patent it and make a fortune] because they have some 'give' built into the high tech clamp. NEVER had a leak.
Personal preference...the Uphonor pipe and fittings should be used as part of a system. Will they work when mixed, probably, but warranty issues might crop up. Uphonor pex is type A. Others may make type A, but it tends to be more expensive than types B or C. Type A is the only type that can be 'dekinked' without cutting out a piece and putting in a fitting. It is also able to provide the smallest bend radius of the other types. Pex has a memory, so on the expansion system, they use a larger diameter fitting than on the crimp systems. With all of the crimp type fittings, the OD of the fitting is about the size of the ID of the pipe so you can insert it. To get that fitting inserted with Uphonor fittings, you have to expand the tubing, then it collapses onto the fitting which provides the seal. Pretty foolproof, and while not huge, the increase in ID is there...a little increase in diameter has a big effect on the area because of the r^2 factor (pi*r*r). increased area means less pressure loss and higher volume available.
If you think the benefits are worth the difference in price (if it exists depending on your supplier), then go with it. They all work.
Ballvalve
That is incorrect. The fittings have about the same ID. The brass may even be smaller because its, well, brass.
The pipe slips over the plastic uphonor fittings by hand without expansion, and the expansion ring gets expanded and slipped over the pipe, giving you just a few moments to get it all right and a good start on arthritis.
ProPex fittings, at least if you believe the manufactuer, cannot be inserted without expanding the tubing first. This line is plastic, been around for over 10-years, and meets the CA lead-free requirements. Plus, are less expensive than the brass ones. Was trying to find an engineering diagram, but as noted earlier, because the area of the opening is a function of the radius squared...a little difference in R, makes a big difference in area, or the opening.
The installations I've seen, there's an obvious bulge at the connector, which implies the tubing has been expanded to fit over the fitting helping to maintain the max diameter.
Ballvalve
You win. I have'nt used the expander for 10 years or more, and it was such a PITA, I blocked it out.
From a practical standpoint, the SS clamps get you into tighter spaces, can be removed easily without shortening the tube, and most important, can be slipped together, the whole system inspected, and all crimps made at once. And you don't need a 450$ tool and their overpriced fittings. Only a chimpanzee can use the hand tool all day and not suffer all night.
If you're doing it for a living, you likely would have the power tool. A DIY'er just doing a few changes, a few fittings, and it's not a big deal. Then, there's always the auction site, or possibly a tool rental place.
Ballvalve
The cinch clamps never need a electric tool. and they are incredible for air line, hose repair, you name it. And you can do it all day with a 40$ tool, and brass fittings that cost less than the patented plastic. I can only say that the uphonor looks 'nicer' but then so do does a Porsche next to a bulldozer.
Lets talk in 40 years when the class action suits start to enrich the lawyers, and see who wins.
Since Uphonor has been making stuff for longer than that, I guess the answer is already in. Feel free to use whatever system you feel comfortable with, they all can work. They each have their advantages and disadvantages.
Ballvalve
I have not researched the history of their connections, which started in Europe, but the expander system seems to be "relatively" new. I used wirsbo tube years before you could buy expansion fittings, in California, anyway.
