PEX expansion loops & droops vs need to drain the line?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by AcidWater, Nov 15, 2008.
  1. AcidWater
    AcidWater Member
    Oct 14, 2008
    The fact that you need to leave expansion space with PEX seems to mean that sloping it for drainage would be a problem.
    Does anyone have a method? Do you just install a lot of drain valves throughout the run?
    I also wonder about well water sediment accumulating in the low spots over the years.
  2. hj
    Pex
    Run it straight and let the expansion take place at the turns/corners.
  4. AcidWater
    AcidWater Member
    Oct 14, 2008
    What about the stretches between Tees ?
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    How long of a run are you talking about?
  6. AcidWater
    AcidWater Member
    Oct 14, 2008
    All the tees are at the tail of the main run, and go out between the joists. So no more than about few feet between each tee, for the most part.
    main run from water tank
    ----------->> tee to clothes washer
    ----------->> tee to bathtubs (two risers so one tee in this line)
    ----------->> tee to toilets (two risers so one tee in this line)
    ----------->> tee to lav
    ----------->> tee to other lav
    to outdoor hose bib, which drains the line
    And I just realized that I can't drain the hot because it doesn't go to a hose bib... maybe I should install a connection to the end of the cold line with a 3 way valve.
Similar Threads: expansion loops
Plumbing Forum, Professional & DIY Advice Thermal expansion tank Dec 22, 2016
Plumbing Forum, Professional & DIY Advice Installed expansion tank now pressure is higher? Aug 23, 2016
Plumbing Forum, Professional & DIY Advice Expansion tank location boiler? Aug 19, 2016
Plumbing Forum, Professional & DIY Advice Relocation Expansion Tank - Hydronic Heating May 4, 2016
Plumbing Forum, Professional & DIY Advice Need advice about expansion tank Apr 10, 2016
