PEX Crimp rings or Clamp rings....Which Preferred ?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Its.me.again, Oct 20, 2012.
  1. Its.me.again
    Its.me.again New Member
    Oct 12, 2012
    Buffalo, NY
    Since I am new to PEX...and just a homeowner...I figured I'd ask which PEX fastener is preferred.
    Do you like the solid copper Crimp rings or the stainless Clamp rings?
    Is there a time when you prefer one application over the other?
  2. jadnashua
    THere's a third choice - Uphonor's expansion rings. THey all work, I'm not sure there is a big difference on the crimp rings. I prefer the Uphonor's system, but it does require a more expensive tool to install (a tubing expander rather than a crimp tool). WIth this system, you insert the tool into the tubing, expand it, slip it over the fitting, then the PEX (with the reinforcement ring) collapse over the fitting. PEX has memory and I like the fact it makes the seal on its own rather than relying on it being compressed. But, done right, they all work. By expanding the tubing, there's less restriction at the fitting, too.
    PEX is made in one of three methods, and designated as -A, -B, or -C. -A is the most flexible and the only one that can have a kink repaired. -B and -C types require you to cut out the kink and insert a fitting. Plus, -A bends to a smaller radius, often requiring fewer fittings.
  4. hj
    I use both, on the few occassions when I use PEX. The clamp/cinch rings are convenient because the same tool does them all without changing "dies".
Similar Threads: Crimp rings
Plumbing Forum, Professional & DIY Advice Ox-Box, F1807, ProPex, and Sharkbite Crimper and Rings May 24, 2013
Plumbing Forum, Professional & DIY Advice What tool to use to crimp PB fitting? What color crimp rings do I use? Nov 10, 2009
Plumbing Forum, Professional & DIY Advice Crimp Rings VS. Compression Fittings Feb 8, 2005
Plumbing Forum, Professional & DIY Advice Apollo crimp ring tool question.... Dec 6, 2016
Plumbing Forum, Professional & DIY Advice PEX crimp over compression question Jun 28, 2016
