EthylOH
Hi all,
New member here...
I've spent hours reading up on this topic, but I still can't seem to decide what my best approach is.
Right now, I'm in the middle of a full master bath remodel. My old shower/tub combo is fed with a 1/2" copper line. I have full access to all the plumbing from my basement.
In the process of demo, I noticed that I don't have shut-off valves for the bathroom water lines, so I put in two 1/2" sharkbite valves. (I can solder, but am no expert. I didn't buy sweat valves due to the fact that I don't want to run a torch 2" away from a wooden joist. Also, the sharkbites are in full view and are fastened in such a way that it is impossible for a catastrophic failure where water would be gushing out).
So my question comes down to this. What is my best approach to plumb in the shower valve, separate tub, and the sink?
If I use PEX or CPVC, wouldn't I have to move up to 3/4" with a coupling due to the fact that the ID is smaller than the copper? Or is 1/2" fine (I will be using a rainhead). How would I do this? Most PEX manifolds go from 3/4" to 1/2".
For reference, here are the fixtures that I bought:
Tub:
http://www.kingstonbrass.com/Center_Wall_Mount_Goose_Neck_Clawfoot_Tub_Filler_p/cc1t8.htm
Shower:
http://www.lowes.com/ProductDisplay...gId=10051&cmRelshp=req&rel=nofollow&cId=PDIO1
valves:
http://pro.moen.com/commercial/1-2-cc-connection-with-integral-stops/_/R-TPORTAL-ALL:8371HD
http://pro.moen.com/commercial/commercial-three-function-1-2-transfer-valve/_/R-TPORTAL-ALL:3360?next=SiteSearch.Link
New member here...
Tub:
Shower:
valves:
