PEX Connections
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by countrylife, May 22, 2011.
  1. countrylife
    countrylife New Member
    May 22, 2011
    Texas
    I have a PEX pipe coming out of my slab that has a black interior, a shiny metalic layer, then a gray outer layer. I'm assuming it's the aluminum oxygen barrier PEX. The outside diameter is .9375 (15/16") so the 3/4" crimp rings I get at Lowe's will not fit.
    Note: it appears that the outer layer of gray has been removed to put a fitting on originally. Experimenting with the pipe and removing the gray puts the metal layer at just over the .875" that is specified for 3/4" pipe. I can't believe that this is the right way to terminate the pipe.
    What kind of crimp rings are supposed to be used for this pipe?
  2. hj
    The fittings and crimp rings made FOR it. It is probably Pex-Al-Pex which was normally only used for infloor heating systems. Hopefully your brand is still in production, because some companies have abandoned the material.
  4. countrylife
    May 22, 2011
    Texas
    I talked to a couple of different plumbing houses today and found out that the pipe is Viega Pex. Also found out that as part of the fitting installation a "reamer" is used to reduce the outside diameter of the pipe. I don't know anything about Viega yet, but I'll read up on them.
Similar Threads: Connections
Plumbing Forum, Professional & DIY Advice Hot and Cold Pex Connections to the Water Heater from Below Today at 7:14 PM
Plumbing Forum, Professional & DIY Advice NPS (Straight Thread) Fitting OK for Hidden Connections? Apr 5, 2016
Plumbing Forum, Professional & DIY Advice Best Pex Manufacture for Cinch Connections? Feb 7, 2016
Plumbing Forum, Professional & DIY Advice Pool filter connections May 29, 2015
Plumbing Forum, Professional & DIY Advice how to buy/make new connections to water meter Dec 31, 2014
