runner1980
Hi, I bought a home which has PRIER C-244 Anti-Siphon Design hydrants installed. To be safe, I prefer to drain the hydrants and shut the water supply to them since it does get very cold in the winter where I live. Unfortunately, the shutoff valve used for the prier hydrant also shuts off water to my kitchen, washer, and dishwasher. I need to install another shutoff valve downstream of the appliances but that area is behind a Sheetrock wall in my basement. Even though the hydrants are anti freeze design, I can't tell if they was installed properly with a slant downwards so the water can drain.
The tubing where I would install the shutoff valve is 1/2 PEX. I did some research and bought the following:
1/2 pex ball valve,
PEX stateliness steel clamps (easier to install and need only one tool than using the rings)
crimp tool
PEX Knife to cut the pipe
Access Panel where the Sheetrock will be cut out
This all cost be about $100 bucks in Home Depot.
When I got home, I looked online and saw that Shark Bite offers a quick connect PUSH-FIT connection shutoff ball valve. The valve is more expensive, around 20 bucks, but the only other tools I would need is the PEX tube cutter. I can save about 50 bucks by installing it this way.
If you were doing this in your home and didn't have any tools, would you install it using the stainless steel clamps or use the push-fit connection? What is more secure?
Thanks
1/2 pex ball valve,
crimp tool
Thanks
