PEX and tight turns...
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by OldPete, Mar 27, 2007.
  1. OldPete
    OldPete DIY Senior Member
    Jan 4, 2006
    NJ
    When doing a job where PEX is being used and you need to use a 90* instead of just bending the pex (tight spot), how confident do you feel about this fitting or do you try to avoid them.
    If you try to avoid them is it because you are concerned about the fitting failing or the cost?
    There is a job going on in my neighborhood where there are A LOT of Uponor ProPex fittings being used in ceiling and joist bays. I'm curious as to how folks feel about this sort of thing verses the home-run methods, etc.
  2. jadnashua
    One of the benefits of using pex is you need fewer connections. This saves on cost. You can run it like copper pipe, and then you need just as many. Sometimes, you don't have a choice. I'd prefer a path that didn't need as many fittings, but other than cost, should be okay. Each fitting adds more restriction which also might mean the calculations on the size needed might no longer apply. A continuous run, because it is smoother is said can be done with smaller pipe in pex vs copper. Throw in a bunch of fittings, and that probably no longer applies. they may notice flow problems if it was sized for the smaller pipe without all of the fittings, depending on how overboard they went.
  4. kordts
    kordts In the Trades
    Oct 15, 2005
    industrial service plumbing foreman
    exurban Chicago
    There are supports that you anchor, then run the pex thru it. You can make real 90's.
  5. OldPete
    Jan 4, 2006
    NJ
    Yes, but only within the limits of the tube... what do you do when you need to make a 90 in 2" of room?
  6. jadnashua
    Re-route it, or put in a joint.
  7. Randyj
    Randyj Master Plumber
    Nov 25, 2006
    Alabama
    Use what you have to use...then go home and get a good night's sleep.
Similar Threads: tight turns
Plumbing Forum, Professional & DIY Advice PEX riser tightening, how many turns at stop? Sep 2, 2007
Plumbing Forum, Professional & DIY Advice Toilet seat won't stay tight Oct 1, 2016
Plumbing Forum, Professional & DIY Advice Replace ABS Closet bend tight space Sep 15, 2016
Plumbing Forum, Professional & DIY Advice How and how much to tighten this pipe? Sep 5, 2016
Plumbing Forum, Professional & DIY Advice Properly tighten black steel gas piping Aug 1, 2016
