PEX and Air Chambers
Discussion in 'Illinois Plumbing Code Questions' started by Garfield, Jun 1, 2011.
  1. Garfield
    Garfield semi-pro
    May 17, 2011
    Remodeler
    Chicagoland
    Chicago suburb, Lake County, and PEX is allowed here. We follow the Illinois Plumbing Code, with a few local amendments that aren't applicable to this issue.
    The local Plumbing Inspector says that air chambers are required at every fixture, even though the manufacturer says that air chambers are not needed with PEX.
    So instead of nice, continuous home runs with just a connection at each end, we now have some 90's, T's, plugs, and many more connections per fixture. I think this really blows and negates several of the advantages of using PEX:minimal # of fittings, fewer joints (possible weak/leak points) and directional change with less pressure loss than 90degree fittings.
    Can someone shed some light here and let me know the reasoning behind this? Why would a plumbing inspector require air chambers with PEX when the mfgr says the opposite? Or is it that they are just so used to copper that they want PEX systems to be run like copper, except they'll let you use plastic. Yeah I did ask, but didn't get anywhere.
    Thanks.
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Try asking about using Water Hammer Arrestors...
    If they say no to that you know you are fighting city hall....
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    They say it because they can.
  5. hj
    PEX does NOT eliminate water hammer, it just absorbs the sound. Properly installed air chambers eliminate water hammer, until they get "water logged" and then they are "permanently" ineffective because there is VERY little likelihood that you will ever get them drained, no matter how many "cures" you are given to try. The manufacturers recommend whatever the engineers, who have NEVER really installed it, say should work.
  6. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    that is a joke
    putting air chambers on every fixture is total overkill...
    I have seen them on occasion
    maybe at the tub and shower faucets...
    perhaps on top of the water heater.....
    and on occasion we see them pre installed in laundry boxes....
    it is probably just another "make work" thing for the plumber
    also it is just a few more joints that could leak sometime in the future
    which the service plumber will simply cut out and eliminate years from now:cool:
    I wonder if you are also required to install a
    PRV valve in every home...and a thermal tank too....
    with a prv valve , and a thermal tank
    would that not also throttle down the water pulseing through the system??
    if you have insepctors that enforce this ,
    then you just have to do it to make them happy
  7. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    I would check again in Lake County. Pex is not allowed by their amendments.
    http://www.lakecountyil.gov/Planning/Building/Documents/Plumbing Code.pdf
  8. plmbrbob
    plmbrbob New Member
    Feb 2, 2014
    Wauconda, Il.
    Some municipalities may allow pex, but not unincorporated areas. For god's sake, they still require cast iron underground. Dinosaurs
