perplexed by our pressure assist toilets
Discussion in 'Toilet Forum discussions' started by moray, Aug 21, 2007.
  1. moray
    moray New Member
    Aug 8, 2007
    Washington
    We recently moved into a house with 2 pressure assist toilets (American Standard). I've never seen these before, so I'm a little confused about how they work and how to fix them...
    The first problem was that the flush on both toilets was really half-hearted. The flappers would shut after only about 1/3 of the tank had drained. To solve this, I adjusted the floats above the flappers (moving them from mid-way along the chain to right down on top of the flappers), and shortened the chains. This seemed to do the trick, and the flushes were a lot better since the flappers stayed open longer.
    Now, I've noticed that the toilets hiss continuously (and occasionally make trickling noises). It's a really quiet hiss, but it looks like a small amount of water is always running down the inside of the overflow tube. Did I make the flappers so buoyant that they're no making a firm seal anymore? Or is this another issue?
    Thanks in advance for any thoughts!
  2. jadnashua
    If the flapper is being held up by the chain, you are constantly dumping water, and be on the lookout for a surprise when you get your water/sewer bill, it could be huge.
    Modern toilets usually do not empty themselves with each flush (the tank, the bowl should!) - they use that height to generate a more forceful flush. Think of a water tower on top of a hill - you get the pressure from the height.
    On a pressure assist toilet, the water goes into a closed tank with a bladder in it and captive air. The water pressure pushes the water into the tank, compressing the captive air. When you flush, instead of gravity pushing the water out for the flush, it is the stored energy from the captive air (compressed by the water pressure) pushing it out. Thus, the water pressure from the supply is 'assisting' the water flow and the resulting flush.
    If you have a typical flapper valve, it doesn't sound like it is a pressure assist toilet.
    The static water height in the tank needs to be high enough to get the proper 'head' in a gravity flush; if it is too low, the water doesn't have as much pressure.
  4. moray
    moray New Member
    Aug 8, 2007
    Washington
    Thanks for the reply and sorry for the confusion (plumbing is clearly not something I understand)...
    I thought that it was a pressure assist toilet because it didn't have a float and had a little yellow tank instead, but my new theory is that it's one of these American Standard Smart Valve 2000 fill valves:
    http://static.zoovy.com/img/dealyard/-/smartvalve_2000
    I've dug up some old threads about these on this forum, and the consensus seems to be that it's a piece of junk :(
    I'm guessing that the rubber seal under the cap may have some debris?
    Or do I need to adjust the height of the fill valve assembly? Or the little tube that goes into the overflow tube?
    The flapper appears to be seated properly between flushes, but who knows if there's a small leak there.
    Any diagnostics that I could try to see what's going on?
    The main symptoms are: very quiet hissing sound, small amounts of water spilling from the tank into the overflow tube.
  5. jimbo
    jimbo Plumber
    That smart valve was so bad that A/S stopped using it a few years ago, and their toilets now come equipped with Fluidmaster 400A. You should replace yours with a 400A or a Korky QuietFill.
  6. achutch
    achutch Member
    Oct 20, 2005
    Vermont
    My sister had in her previous home an American-Standard "New Cadet" which she picked out herself at HD. It came with the yellow "Smart Valve". It was probably a year later when my father called me and in very angry tones asked me to come the next day and put a "proper float valve" in my sister's new toilet because my brother-in-law fooled with the Smart Valve so it wouldn't shut off (since reading the comments about the Smart Valve, I doubt he touched it at all), and it ran the well dry and nearly burned out the bump (she burned out at least 2 pumps in that house).
    I went up the next day and in about 15 minutes installed a Fluidmaster 400A, thus soothing the nerves of my father and my sister.
    That toilet leaked later on from the tank to bowl bolts. They were not installed right (too loose) and one of them had rusted so badly that I had to use a hack saw to remove it!!! I replaced the bolts (making sure the new ones were brass), washers, and the tank to bowl gasket.
    I am using Fluidmaster 400A and Korky Quiet Fill. On a restoration of an antique tank, I occasionally use the Mansfield 09 (for the sound effects), but readily agree that the new styles are more trouble free as well as practical, because they signal you when there is a slow leak in the flapper by turning themselves on for a few seconds.
    achutch
Similar Threads: perplexed pressure
Toilet Forum discussions Toto Drake II -- perplexed by leak Oct 24, 2011
Toilet Forum discussions Gerber Ultra-flush not working well since pressure regulator added Mar 26, 2016
Toilet Forum discussions Pressure assited toilets: best supply pressure and outflow pipe joint stress Aug 27, 2015
Toilet Forum discussions Rim wash issue on Kohler pressure assist Jul 13, 2015
Toilet Forum discussions Standard wax ring vs wax ring with horn - how much pressure should be applied? Apr 28, 2015
