Joe Ejo
My RO system is a 5 stage 100 gal per day with a 40 gallon pressure tank. It has worked adequately for the last 5 years although with limited pressure.
About six months ago, a friend mentioned that a permeate pump would increase the overall pressure of the filtered water.
We decided to give it a try, and added an Aquatec ERP 1000. The results were amazing. The RO water pressure was increased by nearly double and we never ran out of RO water again until:
Two days ago, we were suddenly out of water. I noticed the permeate pump had stopped clicking so I called Watts Premier (where we bought the pump) and without hesitation the tech support guy gave me an RMA number and said if I sent it in they would look at it and let me know if it was repairable or under warranty, but it would take several weeks before I got an answer.
We could not live without RO water that long, so I purchased another ERP 1000 from Watts Premier and sent the 'broken' one in for repair. I am certain it is installed correctly as I removed the old one and installed the new one at the same moment, tube for tube.
I hooked the new one up and still no clicking. (the ERP 1000 is known for its noticeable click when it works). We were getting water, but not at the great pressure as before, more like the weaker stream before we added the pump in the first place.
I called Watts Premier tech support again, and after nearly an hour wait, the tech (same one as before, them must have only one person) said, and I quote, "I don't know what to tell you. I am not familiar with that pump so I could not possible tell you why it is not working". (side note...never buy from Watts Premier).
Anyway, so now I have a new pump, water production at reduced pressure and no idea what to do next.
Here is what I have done:
1. Replaced all filters including the RO membrane which were about 6 months old.
2. Verified that the water coming from the BRINE IN tube to the pump is about 4X the flow that coming from the PERMEATE IN tube. (This seems to be a test for a bad pump, but the pump is brand new so I doubt it is defective)
3. Verified that flow of water INTO the system is at 60 PSI
Can someone with experience give me some advice?
What should I check next?
I seem to recall the pump clicking whenever water passed through it, is that correct, or does it only click when the pressure tank is full or empty?
Any help would be greatly appreciated.
