PermaHeat Bath Heater
Discussion in 'Shower & Bathtub Forum & Blog' started by Pegasus"143", Jun 21, 2010.
  1. Pegasus"143"
    Pegasus"143" New Member
    Jun 20, 2010
    Tx
    PermaHeat Bath Heater Not Powering on.
    I purchased a Permaheat m/n 935113 heater and installed in new tub installation. My problem is that the heater power indicator light is not lit and no heat is produced when pump is running. It is plugged into a seperate GFCI outlet. Also this is a vacuum side pump. Any help with where to start diagnosis would be appreciated.
  2. Pegasus"143"
    Jun 20, 2010
    Tx
    :::UPDATE :::
    Found that there was not enough suction pressure to trip the vacuum switch. By partially blocking the suction port the unit switches on and begins to heat.
    Question now is the switch calibratable or does anyone no where I can order just a switch?
Similar Threads: PermaHeat Bath
Shower & Bathtub Forum & Blog Clawfoot bathtub gurgles Monday at 12:45 PM
Shower & Bathtub Forum & Blog How do I remove these bathtub skirt panels? Feb 16, 2017
Shower & Bathtub Forum & Blog Cold, hot water lines to new bathroom Feb 15, 2017
Shower & Bathtub Forum & Blog Delta Acrylic Bathtub Drain Sealant Feb 14, 2017
Shower & Bathtub Forum & Blog Bathtub Mortar - Should I be worried? Feb 13, 2017
