Perforated down spout tubing
Discussion in 'Irrigation / Sprinkler Forum' started by marc5688, Jun 28, 2007.
  1. marc5688
    marc5688 New Member
    Jun 28, 2007
    I have been landscaping for some time now, and it has come into question as whether to use perforated corrugated tubing or tubing that does not have the perforated holes?
    I am burrying the down spouts for my customer with perf tubes and the irrigation company on site has voiced their concerns on the type of tubing that I am using.
    I have used perf tubes for years with no problems
    Any opionions, either way
  2. Mr_Pike
    Mr_Pike New Member
    Jun 28, 2007
    I see it both ways all over.
    There are arguments for both. If you have trouble with water in your basements in the area, then I would personally install the non perforated version. If you have decent drainage, the perforated version won't hold the stagnant water and tends not to clog in that late winter early spring freeze thaw time. Tell the homeowner you will use what he prefers, but explain why you use what you do, and that different contractors use different stuff.
  4. Kiril
    Kiril New Member
    Jun 19, 2007
    Sacramento, CA
    Each site is unique. Use the appropriate pipe for the situation.
Similar Threads: Perforated down
Irrigation / Sprinkler Forum Looking for a sprinkler type that sprays across and down Apr 16, 2014
Irrigation / Sprinkler Forum Zone will not shut down Jul 2, 2010
Irrigation / Sprinkler Forum Pressure up and down, surging heads Feb 11, 2009
Irrigation / Sprinkler Forum Iron Pipe shut off valve wants to point down Jun 3, 2008
Irrigation / Sprinkler Forum Antisiphon valves downstream of reduced pressure backflow device Jul 9, 2007
