Pegasus series 7000 cold water faucet cartridge removal
shawv
I need help with Pegasus series 7000 cold water faucet cartridge removal.
I took the screw out of the handle and can grip the part that the screw goes into with needle nose pliers, but I can't get it out of the housing that goes around the cartridge. I have turned it 360 degrees while lifting it and it wont come out. I have also attempted to turn the houseing that the cartridge goes into but it won't turn.
I am having a problem as I turn off the faucet it turns off about 1/2 way back and as you continue to the stop it turns back on.
HELP!!!!
shawv
HELP!!!!
Here is a picture
Jimbo
San Diego, CA
I am sure you need to remove that bell shaped trim to access and repair the stem. It probably just unscrews. If you have trouble , the Pegasus/Glacier Bay toll free number often is helpful. The phone number can be found on the instruction sheet, or just go into a depot store. The number is printed on the outside of every glacier bay box.
