Pedestal Sink Mounting Bracket
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by RL1964, May 25, 2008.
  1. RL1964
    RL1964 New Member
    May 25, 2008
    Hi everyone, I purchased a WaterRidge (which I think is made by Danze) pedestal sink from Costco a couple of years and either did not get mounting brackets or lost them. I cannot for the life of me find anything! Home Depot has nothing and I cannot find anything on the Net, even at the "large" plumbing supply sites. It seems like such a simple part! Doesn't anyone make generic ones that fit multiple sink manufacturers? UGH!:)
  2. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    Some pedestal sinks do not come with mounting brackets. They rely on the pedestal leg and 2 - 3/4" holes behind the sink (if it has any). The 2 holes behind the sink would be for bolts to lag into the wall.
    Check the design of your pedestal sink to see if this is the case
  4. RL1964
    RL1964 New Member
    May 25, 2008
    I wouldn't really call them "holes" per se. They are more elongated "slits" I'd call them... I don't even see how a bolt head would fit through...
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    It may be tough to take this but buying plumbing fixtures from Big Orange or, Blue Box would be a quantum leap in quality over what you will find at Costco.
  6. hj
    holes
    The "bolt head" does not go through them. The bolt, or lag screw, goes through the opening and the bolt head stays outside with a washer between it and the sink.
  7. RL1964
    RL1964 New Member
    May 25, 2008
    I'm sorry I am having a tough time envisioning that...
  8. jadnashua
    Picture a lag bolt shaft with a machine screw threaded shaft on the other end (no head, just shaft). You use two nuts, tighten them up against each other, screw the lag bolt end into wood blocking in the wall, then take the nuts off, slip the shaft through the hole in the sink, install a washer, lock washer, and nut on the shaft to tighten it up. SOmetimes they are called a hanger bolt. Pick a pair up at any good hardware store in various thicknesses. Sometimes you can find them at a big box store. Obviously, get one that will fit through the slot in the sink. If you don't have something solid in the wall to anchor it to, you should tear up the wall and install some.
  9. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    Here is a pic of a hanger bolt.
    Screw the bolt into the wall, place the sink so that the holes line up with the bolt, then place your washers and nut.
      File size:
      7.1 KB
      3,591
Similar Threads: Pedestal Sink
Plumbing Forum, Professional & DIY Advice Removing hardened caulk from behind pedestal sink/tiled wall Jan 23, 2017
Plumbing Forum, Professional & DIY Advice Extending cast iron drain line for pedestal sink Nov 25, 2016
Plumbing Forum, Professional & DIY Advice Angle stops for pedestal sink (FIP vs compression) Aug 9, 2016
Plumbing Forum, Professional & DIY Advice A few pedestal sink questions Aug 3, 2016
Plumbing Forum, Professional & DIY Advice Pedestal sink leak on drain, how to fix it. Jun 25, 2016
