Pedestal Sink Installation
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by BacciJack, Mar 3, 2013.
  1. BacciJack
    BacciJack New Member
    Mar 3, 2013
    SE Alaska
    I bought a new home last year and the previous owner had not attached the pedestal sink to the wall. So now I am trying to complete the installation correctly. My problem is that I think I am missing some of the mounting hardware and am hoping that folks can point me in the right direction.
    The sink is manufactured by Hometek. I can't find a model number listed anywhere on the fixture. When I do an internet search for "Hometek sinks" I only get a handful of results, none of which is helpful. (I was hoping I could find online installation instructions.)
    Here is a photo of the mounting holes at the back of the sink.
    As you can see, there are just two large holes (about 1" long ovals). I am assuming there is another piece of hardware that fits into these holes to complete the installation??? Does anyone have experience with this style of pedestal sink who can give me some tips or direction?
    Thanks for any assistance.
  2. jadnashua
    On the few I've dealt with, they just used a hanger bolt (a headless bolt with a coarse wood screw thread (lag bolt) on one end and a normal machine screw bolt's threads on the other), a big fender washer or a bar connecting both holes, and a nut. The bolt needs to go into blocking in the wall. If you used something like a lag bolt, the coarse threads would make snugging it up too dangerous. A little silicon caulk on the back will also act like a good glue.
    www.wingits.com also makes some good wall anchors.
  4. Terry
    Aug 17, 2004
    Just pick up some toggle bolts and fender washers.
    The fender washer prevents the nut from pulling through those large holes.
  5. BacciJack
    Mar 3, 2013
    SE Alaska
    Oh, of course. Don't I feel silly!
    Thanks for the quick and helpful reply!
  6. hj
    I have always just "glued" the sinks to the wall with a silicone caulk. NONE have ever come loose.
Similar Threads: Pedestal Sink
Plumbing Forum, Professional & DIY Advice Removing hardened caulk from behind pedestal sink/tiled wall Jan 23, 2017
Plumbing Forum, Professional & DIY Advice Extending cast iron drain line for pedestal sink Nov 25, 2016
Plumbing Forum, Professional & DIY Advice Angle stops for pedestal sink (FIP vs compression) Aug 9, 2016
Plumbing Forum, Professional & DIY Advice A few pedestal sink questions Aug 3, 2016
Plumbing Forum, Professional & DIY Advice Pedestal sink leak on drain, how to fix it. Jun 25, 2016
