PE pipe work for deep well jet "packer ejector" ?
Discussion in 'Pumps and Tanks Well Forum & Blog' started by David Alan, Dec 21, 2009.
  1. David Alan
    David Alan New Member
    Dec 21, 2009
    East Texas
    Elsewhere, one fellow commented (in Florida) that he sees PE pipe used on deep well jet pump ejectors.
    (He didn't say in what size casing exactly...)
    I am trying to set a 'packer ejector' down to 70' depth (in a 95' deep, 2" PVC cased new well).
    Any chance PE pipe can be used in my situation ?
    Many thanks for your help.
    David :)
  2. Gary Slusser
    Retired
    I don't think so, it may not be stiff enough. Sch 40 PVC would work.
  4. David Alan
    Dec 21, 2009
    East Texas
    Thanks for your reply.....
    Thanks for confirming, Gary.
    On Sch 40, do you mean with carefully solvent welded joints or using M/F Adaptors or ???
    Thanks,
    David Alan :)
  5. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    I've set packers on PE but not PVC cased wells.
    I don't think I would use glue joints. You need thinwall couplings
  6. David Alan
    Dec 21, 2009
    East Texas
    Peter, thanks for your reply
    What were the wells cased in & their size ?
    Mine is 2" PVC....
    David
  7. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Steel and 8"
  8. Gary Slusser
    Retired
    "Carefully" or not man! glue the stuff up after using cleaner or primer and yer done.
    You use solvent welded or threaded couplers and I don't know of any other widely used way but there is a rarely used and hard to find PVC pipe system with pinned bell connectors.
    I would use threaded couplers only because at some time in the future you will be pulling the stuff out of the well and if you want to reuse it, you don't want to cut it and use more couplers to put it back in the well.
    You've been told you can't use bell ended anything because of the clearance needed in your 2" pipe. Now getting thin walled threaded couplers seems to be the only way to go because PE may not be able to be used because of what you said about it earlier not going into the packer right. So put things on hold until you get the right couplers and then go for it.
    IMO you should have drilled at least a 5" well and used a submersible pump.
    PE is used on submersible pumps to 500'+/- and single/two line shallow/deep well jet pumps but not vertical jet pumps and probably not with packer type systems.
  9. David Alan
    Dec 21, 2009
    East Texas
    Gentlemen, thanks for your helpful replies.
    With what you all are making plain, I will with any future wells, drill large enough for a submersible pump.
    Honestly, I was hoping to not have to go 95', and only having room for a 2" casing.
    Maybe I should reconsider setting the jet at 70', a bit higher up, say 60'. The static water level is 10'. I don't want to run dry. It sounds like I'm on the ragged edge of what a deep well jet pump can do, eh.
    On couplers, they say you can't thread Schedule 40 due to insufficient wall thickness. Do you agree ? If so, it would seem to leave few options......
    Many thanks,
    David Alan
  10. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    nope, sch 40 is way too thin to thread. Well actually it will thread, but the threaded area will be so weak that I would never trust it. Sch 0 though threads just fine.
  11. David Alan
    Dec 21, 2009
    East Texas
    Peter,
    Yes sir, that makes sense. With no readily available source of Schedule 80, it's 'back to the drawing board', it would seem....
    Long drive towards Houston (2.5 hours) to find Sch 80 & thin-wall Couplings or........
    thanks, David
Similar Threads: pipe deep
Pumps and Tanks Well Forum & Blog How to get drop pipe out of deep well? Apr 25, 2014
Pumps and Tanks Well Forum & Blog Deep Well Single Pipe Packer - Jet Pump Priming Question Aug 6, 2013
Pumps and Tanks Well Forum & Blog 2 inch deep jet well single pipe help Jun 8, 2012
Pumps and Tanks Well Forum & Blog Water pipe in deep well Oct 17, 2011
Pumps and Tanks Well Forum & Blog two pipe deep well jet pump Aug 9, 2009
