semipro
Does anyone know of a good domestic source for parts for this thing? The Grundfos part number is 96526653.
More: My Grundfos MQ 3-35 booster pump has started to act up. Its short short cycling, staying on only 10 sec. regardless of water demand. It then restarts after about 20 sec. I've checked a few things and believe that the spring in the pressure switch may have broken. I removed the pressure switch to check it our and the adjustment screw seems too easy to adjust. I adjust it in clockwise (in) to increase the pressure threshold and the operation of the pump improved quite a bit. The pump operates nearly continuously now under demand.
BTW, if I'm on the wrong track I'd be glad to know it.
