petepdx
I've getting close to start putting together all the parts for my little project. Inside will be a 'place holder' for a CSV (couple unions spaced for a future CSV1A, pressure tank, air/water mix tank, and an iron removal Fleck/tank.
Except for the 1" PE pipe from the well that is so nicely inside the concrete floor and the cast brass tank tee on the pressure tank, everything is PVC 40/80 and 304/316 Stainless.
The site will be going through some extensive rebuilding, hence the location of all the above may have to moved out of the way from time to time.
To the question. Has anyone used and has comments on using Park quick disconnect fittings ? I don't want to make it look like I'm plugging any seller but if you put "Park QD fittings -parker" in a Google Images search the first few show them. I've also seen them called SDI fittings.
