Parallel Water Heaters - Want to Install Recirc Pump
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by zman98, Dec 8, 2005.
  1. zman98
    zman98 New Member
    Dec 8, 2005
    Hi All,
    I'm new here. Hope you folks can help.
    I have finally tired of my wife complaining about waiting for hot water at the shower. I am looking at the Grundfos Recirc pump. I have a question:
    Since I have two water heaters running parallel will I need to install two pumps or just one pump where the two hot water out lines connect? I'm thinking one will work but I thought I would ask.
  2. Cass
    Cass Plumber
    Nov 12, 2005
    First, in order for the circulating pump to work you need a return line so the water can circulate. Do you have a basement and is it finished.
  4. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    pump install
    if you have two water heaters in parrell,
    you are going to have to install the return line
    into the cold inlet to the water heaters BEFORE it
    divides off to both units, and you will have to install
    a spring loaded check valve before this connection
    to keep the water from going back up the cold line..
    ps......you are opening a huge can of worms here because
    all you are realy doing is spoiling your wife, once she realizes
    that you are willing to go through all this trouble to please her
    it will never end...
  5. hj
    pump
    One pump in the common outlet pipe will do find. But you will need a "Comfort" control valve at each "far end" of the piping system.
  6. jimmym
    jimmym New Member
    Nov 21, 2005
    New York
    A wise man.
    Your name should be "master AND plumber mark".
    zma98,
    All you're doing is reinforcing the idea that her nagging gets her what she wants. Like giving in to those screaming kids in the grocery checkout line. If the dog takes a leak on the carpet, do you give it a bone?
    You can lead a horse to water, but cannot make it drink.
    But if it does, it'll expect you to lead it everywhere anytime it wants anything!
    Now, that said, do you want a project? If so, go ahead. Plumbing and building stuff is fun.
    Like my buddy Sean said to his daughter when she asked why we were working on our project in the garage. "Honey, a project is something Daddies do when they want to get away from the Mommies."
  7. Master Plumber Mark
    Feb 6, 2005
    thats a good saying
    that is a very wise saying that you posted
    I will remember it
    another good saying...
    Never give a sucker an even break......
    because if you do, he will never learn aything from the experience
    of being someones chump..,
    and will just keep repeating the same mistake over and over agian.
  8. Cass
    Cass Plumber
    Nov 12, 2005
    Mark, I like it, you can boil it down to this:
    One thing man never learns from history is,
    that man never learns from history.
  9. jimmym
    jimmym New Member
    Nov 21, 2005
    New York
    Sorry about the smart a** comments.
    I thought that you should put the water heaters in parallel. That way you are assured that one is not doing most of the work because of uneven flow.
  10. zman98
    zman98 New Member
    Dec 8, 2005
    Thanks guys. Love the humor.
Similar Threads: Parallel Water
Plumbing Forum, Professional & DIY Advice Two water heaters in parallel Jan 13, 2016
Plumbing Forum, Professional & DIY Advice Parallel PEX water lines? Jan 2, 2016
Plumbing Forum, Professional & DIY Advice Best way to parallel pipe two different sized hot water heaters Jan 26, 2014
Plumbing Forum, Professional & DIY Advice Water heaters piped in parallel Feb 19, 2007
Plumbing Forum, Professional & DIY Advice supporting pnc parallel to Ijoist Nov 21, 2007
