Panasonic Vent Fans
Discussion in 'Remodel Forum & Blog' started by chefwong, Sep 25, 2011.
  1. chefwong
    chefwong Member
    Jun 14, 2006
    District of Columbia
    Just looking at Panasonic vent fans for a bathroom remodel.
    Found a interesting review over at Amazon...I'd figure I'd check in with ya'll
    What vent fans have you guys worked with & or any experience with the Panasonic units..
    Cut-N-Past Review Here
    Be careful here!
    This unit has an outlet duct of 5 19/32" which DOES NOT match any standard ductwork.
    I ended up using 6" flex duct that was crimped down to the outlet duct via a 6" clamp but that's hardly professional.
    I suppose this unit is designed for a market other than the USA.
    The electrical outlet box is mounted (tack welded) directly on top of the housing flange which means you must cut a sheetrock opening
    that will compensate for this outlet box dimension. (otherwise the outlet box would come in direct contact with the ceiling sheetrock).
    You will then have to purchase a 6" to 4" duct adapter if using as a replacement and exhausting via the roof or soffit. Again not ideal for air flow.
    The unit is very quiet but look for a unit with a more standardised dimension otherwise, you will vastly complicate your install.
  2. SteveW
    SteveW DIY Senior Member
    Feb 11, 2005
    Omaha, NE
    I needed a powerful, quiet bathroom fan for mounting VERTICALLY. The only one I found at the time was a Panasonic. I have had it in place for about 10 years. It is "fan-tastic!" Extremely quiet and very powerful. It will pull the bedroom door open if it is closed but not latched.
  4. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    I was going to order one when I realized that my existing fan blows straight up out through the roof with no bends in the duct.
    Are there any good fan units that exhaust out the top?
  5. nukeman
    nukeman Nuclear Engineer
    Nov 20, 2009
    Nuclear Engineer
    VA
    I installed a Panasonic fan and it is great. Super quiet. Mine is in a small bathroom, so I got an 80 CFM model. 4" outlet and no problems attaching to standard 4" rigid ducting. I didn't have any problems with the junction box (my bath was getting all new drywall anyway, but I don't see what that reviewer is talking about unless his model fan is quite different). These fans also have a bunch of different ways to mount them (I think mine had 4-5 options) and you select which option works best (which can depend if new work or a remodel).
    Cacher: I'm not sure if Panasonic has any top outlet fans or not, but I do know they make some nice inline fans. You could do a return air box/grill like you would use for HVAC, run 4"-6" duct up to your inline fan, and then vent out the roof.
  6. chefwong
    chefwong Member
    Jun 14, 2006
    Is Ridgid or Insulated Flex Duct. I have always had ridgid installed.....but this was more for kitchen exhaust, dryer, etc....
    Bearing uninsulated space, I'm thinking the insulated duct may be a option to consider. Plus, it may be quieter versus ridgid. My run is a straight shot, no elbows, 2 feet run at max.
  7. nukeman
    Nov 20, 2009
    Nuclear Engineer
    VA
    I used rigid. I like it better than flex. Mine is all within conditioned space, so the insulation wasn't needed. I think in your case, I would do rigid and then wrap with duct insulation. You get better flow through rigid and I've seen cases where the flex can break down with age. Either one will work, though.
Similar Threads: Panasonic Vent
Remodel Forum & Blog Panasonic Vent Fan Installation May 5, 2010
Remodel Forum & Blog Bathroom Vent Fan - NuTone vs. Panasonic Dec 4, 2007
Remodel Forum & Blog Difference between Panasonic bathroom fans? Nov 2, 2011
Remodel Forum & Blog Which panasonic bathroom fan? Jul 22, 2008
Remodel Forum & Blog Panasonic Whisper Warm? Nov 29, 2006
