painting melamine surfaces with glidden gripper
Discussion in 'Remodel Forum & Blog' started by samarireay, Feb 21, 2007.
  1. samarireay
    samarireay New Member
    Feb 16, 2007
    I am planning on painting my melamine cabinet doors with Glidden gripper. Can I use a regular latex paint as a topcoat or do i have to use a oil based top coat.
    I am really frustrated with this problem. There is so much conflicting advise out
  2. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    As long as "regular" does not mean "run-of-the-mill", I believe you should be able to use any latex that will give you the finish you desire. The only serious conflict I know about that can take place between different types of coatings/paints is when lacquer (or something "strong" as to cutting) is applied over anything else that is weaker and not yet fully cured. And of course, your best result will likely be attained by spraying onto a properly prepared surface.
  4. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    What does the Glidden can say about the topcoat?
  5. zimmee66
    zimmee66 New Member
    Feb 28, 2005
    Des Moines, Iowa
    Seriously consider a trip to a pro paint shop...
    I'm not a big fan of Glidden gripper, I'm guessing you bought it at Home Depot or the like.
    That said, it WILL do the job, but spend as much as you dare on your topcoat then. Latex Enamel will work fine but you need a paint with lots of solids and binders. That generally means expensive paint.
    Alkyd (Oil) enamel will work very well as a topcoat too, but will be very expensive. It does leave a superior finish. Your best job would come from
    Shellac sealer, oil primer and topcoat. But it would be timeconsuming, expensive, and stinky.
    If you really want the finish to last and not chip (the main problem with painting melamine) scuff the melamine with 150 sandpaper or use a liquid deglosser, wipe it CLEAN, and use a *better* bonding primer like Benjamin Moore or Sherwin Williams PrepRite or another top-end product. Consider adding a little flow-conditioner ("Flotrol") to your topcoat paint to smooth the aplication of the finish.
    At the risk of sounding snotty--you will save a lot of time and frustration
    getting the advice of a pro-grade store if you have one in your area.
    Worst case: you'll have a finish that mars, is perpetually sticky, and suffers other annoyances.
    Sometimes local small hardware stores can have pretty smart paint folks too.
    I'm sure you want the job to look great, and better grade paints make that easier to do.
  6. jimbo
    jimbo Plumber
    Good advice from Zimmee.
    This is not a routine job. It can work out for you, or it can be your worst nightmare. This is one job where scrimping on material costs. or prep work, will hurt you.
    At the box store, they might have ONE guy working there with a strong paint background. He will be the guy on Saturday morning with 15 people lined up waiting to talk to him! Best bet as Zimmee said is go to your local pro paint shop.....around here it could be Frazee or Vista Paint or Sherwin Williams, and there a couple of others. Yellow pages will identify the shops in your area. Those guys will steer you straight.
Similar Threads: painting melamine
Remodel Forum & Blog Painting Dec 26, 2012
Remodel Forum & Blog Need some guidance on an exterior painting problem Sep 13, 2012
Remodel Forum & Blog painting new drywall May 30, 2010
Remodel Forum & Blog painting walls Apr 28, 2009
Remodel Forum & Blog Painting Tile Aug 13, 2008
