Paint / Moisture in Bathroom
Discussion in 'Remodel Forum & Blog' started by chefwong, Oct 17, 2010.
  1. chefwong
    chefwong Member
    Jun 14, 2006
    District of Columbia
    I just can't my finger on it quite yet....
    Bathroom Ceiling. It's just the perimeter of the ceiling about 1/4 + 1/16" or so the paint is loosening from the ceiling. In a couple of places, it has come off, in the remainder it just looks suspect. Taking a taping knife to it, but the paint does not come loose...but I know it's somewhat loose. And it's only the edges....
    I plan to just take a sander, sand it with 120 grit ....mud blend if it's bad and then prime/paint.
    Has anyone come across such a issue. I don't think it's a moisture issue in the bathroom....but I can't think of anything else that would be causing this...
  2. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    You're going to do some damage with a palm sander and 120 grit...
  4. chefwong
    chefwong Member
    Jun 14, 2006
    Scraping it with a taping knife is not knocking it loose/loose.
    It's not blistering but I can ~see~ that it's not 100% secure....
    So before I plan to repaint, it's only as good as the base it's on.
    I don't mind destroying the edges to get to the point where I can mud and make it clean...
    Just can't put my finger on WHAT is causing the issue.
    If it was moisture, I would assume that other areas of the ceiling would blister...
    The only issue is as described. Just 1/4- 1/16"+ around the entire edge .
  5. jadnashua
    Did you use premixed mud (it can resoften if it gets damp)? Do you have and use an exhaust fan? What kind of primer and paint did you use? In a bathroom, you want a good sealer/primer and at least a semigloss paint (that's a bit more moisture resistant) than a flat paint.
  6. jimbo
    jimbo Plumber
    San Diego, CA
    I think any paint which does not scrape off is adhered well enough to hold another coat. Hand sand to feather the edges if you must. Taking an electric sander to a ceiling is a messy job.
    Moisture is the enemy.
  7. chefwong
    chefwong Member
    Jun 14, 2006
    If I had to guess, the base primer was probably 8 year old BM Regal (note the current B Regal lineup is not the *old skool* Regal lineup). The exterior paint was Muralo Ceramic or Pratt & Lambert. Overall, the paint has held up and I've noticed the starting to possibly chalk corners about 2 years ago.
    Bathroom is finished tile floor to ceiling. The only paint is the ceiling...
    I may just try hand sanding, using a Zinnsers *paint/primer* that is meant for possibly ~loose paint~, paint 2X coats of that and then paint away....
    I've got to play with a test patch and see how well it goes.
    I hate working facing up ;-)
Similar Threads: Paint Moisture
Remodel Forum & Blog What to do about chimney (paint/spalling) Oct 2, 2015
Remodel Forum & Blog I have to share: fastest way to clean a paint brush. 2 flushes. Oct 6, 2014
Remodel Forum & Blog Painting Dec 26, 2012
Remodel Forum & Blog ceiling paint is cracking/flaking Sep 17, 2012
Remodel Forum & Blog Need some guidance on an exterior painting problem Sep 13, 2012
