P-Trap to vent minimum, Weir to Vent question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by mahuska, Aug 23, 2013.
  1. mahuska
    mahuska New Member
    Aug 10, 2013
    iowa
    When sizing the weir to vent minimum on a P-trap is it measured from liquid edge in trap to start of vent inner diameter (=> than 2X trap arm diameter)?
  2. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    It is measured from the liquid edge to the start of the vent, but it is impossible to not meet code requirements given the configuration of the fittings available. Set that quandary aside and move on to the next one.
  4. mahuska
    mahuska New Member
    Aug 10, 2013
    iowa
    I have a tight shower location using a Kerdi line drain and if you use 2 pipe diameters as the minimum then the weir to vent distance is 5.75. If I just put the P-trap right on the 2" tee the distance is 3.75.
  5. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    I don't know what your pipe size is, but the minimum vent distance is never going to be 5.75. It's 2 pipe diameters -- inner diameter. 1-1/4" pipe will be 2.5" minimum. 1-1/2" pipe will be 3 inches. 2 inch pipe will be 4". 3 inch pipe will be 6 inches. See page 3 of this document: http://www.klickitatcounty.org/documentcenter/view/103
    One thing that is slightly confusing about that document, however, is that it says the minimum "trap arm" distance is whatever, but it illustrates the measurement for meeting code the correct way, then illustrates the "trap arm" as a different distance. The measurement you want is the illustration that shows the distance as being from the inside of the weir to the outer wall of the vent. not the "trap arm" markings under the connection points.
  6. mahuska
    mahuska New Member
    Aug 10, 2013
    iowa
    Ok inner diameters make a lot of sense. 2 in pipe for a shower.
  7. hj
    Unless you have an "anal retentive" inspector with a ruler, no one will ever check it , at least none have ever turned my installations down even with a trap tight to the tee.
  8. hj
    Don't you just love idiots who post a long gibberish filled post in a foreign language, and then repeat it several times to be sure we don't miss it?
  9. mahuska
    mahuska New Member
    Aug 10, 2013
    iowa
    I feel that I missed something
  10. Jamie Smith
    Jamie Smith New Member
    Mar 9, 2016
    Virginia
    Just had one today...
Similar Threads: P-Trap vent
Plumbing Forum, Professional & DIY Advice P-Trap Weir and Vent Line Height Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Bathroom Sink P-trap backup and glug sound "un-vented" Feb 8, 2016
Plumbing Forum, Professional & DIY Advice Can you join 2 p-trap arms (horizontally) before the vent? Jan 24, 2012
Plumbing Forum, Professional & DIY Advice Distance from fixture to roof vent stack layout review (not distance from p-trap) Nov 30, 2011
Plumbing Forum, Professional & DIY Advice angled vent stack and flexible p-trap Jul 6, 2010
