p-trap problems
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by kdenault, Sep 9, 2005.
  1. kdenault
    kdenault New Member
    Jul 31, 2005
    Pediatric Occupational Therapist
    Bucks Cty, PA
    Now, I'm installing a new vanity to replace a pedestal sink in my bathroom. I purchased a new p-trap kit. The vanity has clearance in the back to allow for the hookup. The water supply and the drain are in the wall. The water supply fits nicely in the clearance. The problem is the drain in the wall. It falls about 1 inch below the clearance opening in the vanity. If i cut into the back of the vanity to clear the drain, it will probably effect the structural integrity of the vanity as it will mean cutting into the only cross piece in the back. Is there a flex tube that can be used to connect the wall tube of the p-trap to the drain in the wall--in other words, I would connect the flex tube to the drain in the wall, bend it upwards (like an 'S') and then connect the wall tube to the flex tube? I would still have to pull the vanity out from the wall some to allow clearance for the flex tube, but the amount would probably be less with a flex tube and I can't see any other way around it. Any suggestions would be helpful.
    Kathy :eek:
  2. thezster
    thezster New Member
    Jul 18, 2005
    Retired young... day trade stocks - and to keep bu
    Fort Collins, Colorado
    Can you add another crossbrace to the vanity a few inches higher/lower? As you're going to screw your vanity into the wall studs (you are, right?) - you don't want it a couple of inches off the wall.... Just a thought.....
    necessity is the mother of invention....
  4. kdenault
    kdenault New Member
    Jul 31, 2005
    Bucks Cty, PA
    oooh--good point! The wall behind is all tile, so i'd have to drill holes into the tile and use anchors. Didn't think of that. Well, there is another crossbar higher up about six inches from the top. If I were to drill out a half circle in the lower crossbar--will that leave enough support?
Similar Threads: p-trap problems
Plumbing Forum, Professional & DIY Advice P-Trap Under Floor Feb 6, 2017
Plumbing Forum, Professional & DIY Advice P-Trap Weir and Vent Line Height Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Is this shower p-trap j-bend backwards? Feb 2, 2017
Plumbing Forum, Professional & DIY Advice How do I connect a p-trap to this waste connector? Jan 25, 2017
Plumbing Forum, Professional & DIY Advice The lav cabinet draw hits the P-trap, and how to fix that. Jan 14, 2017
