New here, and a non-plumber.
I replaced the drain in a pedestal sink. Used the original p-trap. The p-trap didn't leak before, but now does.
I tried to replace the nut portion with a new one, but the new threads do not match the original glued portion.
Put more teflon tape, and tighten it pretty tight still water drips. Will plumber's putty work?
If the only option is to replace the glued portion, how do you remove it?
Help! Thanks!
Help! Thanks!
