P-trap install
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by lhoward145, Apr 17, 2008.
  1. lhoward145
    lhoward145 New Member
    Jan 15, 2008
    Removed fiberglass shower and building a ceramic tile shower. Will be installing Kerdi drain. If I place the new Kerdi drain on the existing 2" PVC vertical that exists the P-trap, the Kerdi drain will be 6" off the bathroom floor. That is to high given that I also need at least 2" above the drain for the curb.
    Question: Can I replumb the P-trap by moving it vertically down so the Kerdi drain can be lower? This will put bottom of P-trap near bottom of horizontal waste pipe.
    Thanks
  2. jadnashua
    From the outlet of the p-trap, it has to slope down from there.
  4. lhoward145
    Jan 15, 2008
    Not sure I understand. Can I reposition the P-trap lower?
    Thanks
  5. hj
    trap
    Unless it was not installed properly in the first place you cannot lower it. but, if it was to an existing shower, it should already be low enough and you just have to shorten the riser pipe.
  6. lhoward145
    Jan 15, 2008
    Got it. Thanks for your help and time.
Similar Threads: P-trap install
Plumbing Forum, Professional & DIY Advice Kohler P-trap CP-9033 installation Apr 22, 2013
Plumbing Forum, Professional & DIY Advice Installing pvc p-trap .. how to connect to metal pipe from wall (no threads) May 8, 2011
Plumbing Forum, Professional & DIY Advice Can the J bend in a p-trap be installed "backwards"??? J-Bend Lo Inlet Jul 9, 2009
Plumbing Forum, Professional & DIY Advice P-Trap installation May 14, 2008
Plumbing Forum, Professional & DIY Advice Bathroom Sink P-trap backup and glug sound "un-vented" Monday at 2:27 PM
