Baumgrenze
During the summer of 2010 we did some remodeling. The contractor installed a new vanity in the master bath. I was tired of the stem leaks and incomplete shutoff I've come to associate with classic rubber washer p-stops when they are needed, so I asked for quarter-turn ball valves.
Tonight, at 9:00 PM, on a Friday night I was disappointed to see water flowing out of the vanity and onto the bathroom floor. I shut off both the hot and cold p-stops but the leak did not stop so I shut off the water at the main shutoff, hunted up my tools, and pulled off the p-stop and replaced it with a 1/2" schedule 40 PVC cap I had in my sometimes denigrated pile of used parts too good to junk. By 9:45 we had the water back on and the leak corralled for the time being. My bride of 52 years was more pleased than my 75-year-old body. I thought I was done in the small corner vanity for a while.
I need analytical help to effect a long term solution. Here is what I could see before I shut off the water. I didn't want to fiddle while it leaked. The leak appeared to be a 'knife-edge" shaped sheet of water coming from the valve. I think it is a decent product. The handle reads BrassCraft quarter turn. Could it be that the Teflon tape on the joint failed? The corrosion I can see in the valve appears greener than copper verdigris. I know that brass has been respecified to eliminate lead. Are we seeing galvanic corrosion as a result of connecting 'new brass' fittings to copper plumbing? Is my wisest course of action to buy a new p-stop and install it or should I try fresh Teflon tape and a reinstallation?
It was the cold water line that failed. Should I be anticipating a failure of the hot line?
Thanks,
baumgrenze
Thanks,
baumgrenze
