Overflowing well
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by wieselk, May 25, 2006.
  1. wieselk
    wieselk New Member
    May 25, 2006
    My well is overflowng out the top of the well casing and making my front yard a swamp. I have a 1" inch overflow pipe that runs from the well casing to the woods in the back of my house approximately 150 feet. The overflow pipe always has water coming out but it is only slightly greater than a trickle. I have started to dig up the overflow pipe to see if it was crushed or broken and have not found anything yet. Once I have the pipe uncovered I am considering changing the pipe to a 2" pipe by putting a converter 5 feet or so away from the well casing, but I am worried that it still won't be flowing great enough out of the well. I am not sure I want to get into changing the adapter from the casing becasue I know that can be a cause of contanimation.
    I open to all suggestions but I am trying to do it myself.
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Valveman
    You should have a well seal that does not allow water to flow from anywhere except the over flow pipe. If the over flow pipe is not crushed or pluged, you may have a bad gasket in your well seal. If it is letting water out, it can certainly let contamination in. A picture might help explain your problem but, if you don't want to mess with the well seal, you should probably call someone.
  4. wieselk
    wieselk New Member
    May 25, 2006
    I actually did have someone come and put a new cap on the well and it is suppossed to be watertight but it has a screened air vent that the water is coming out of. Should the cap be sealed so water can't get to that air vent?
    It is a campbell well cap WTC6 seal cap. I was told that the air vent needs to be there and can't be plugged becasue it may create a vacuum in the well.
    This is the website with a picture of the well cap.
    http://www.campbellmfg.com/catalog/l01.htm
  5. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    Don't worry about a vacuum in the well, that's an old wives tale. Just plug that little hole the screened fitting now occupies and all may be good.
    bob...
  6. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    If you can make a connection at the vent using some kind of rubber seal that permits you to adapt a pipe, then here is a means of getting both a vent and stopping the flow.
    Connect the pipe where the vent was and run a small PVC pipe up in the air. You might want a 1" or larger pipe just for stability. Use a post or stake to hold it vertical. Put a pair of elbows on the top so the last one is pointing down and put a piece of screen over it. The pipe must be high enough so no water comes out of it.
    You probalby don't even have to cement the pipes so it will be easy to remove when the water table drops.
Similar Threads: Overflowing
Pumps and Tanks Well Forum & Blog. Water is life. Sand overflowing in drilled well Oct 20, 2011
Pumps and Tanks Well Forum & Blog. Water is life. How to chlorinate an overflowing well.... Jul 17, 2010
Pumps and Tanks Well Forum & Blog. Water is life. Well overflowing around pipe May 4, 2009
Pumps and Tanks Well Forum & Blog. Water is life. Overflowing Artesian Well Dec 15, 2008
