Overflowing Artesian Well
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by crash247, Dec 15, 2008.
  1. crash247
    crash247 New Member
    Dec 15, 2008
    I am a newbie to this so please excuse me if I don't use the proper terms. I have an older well that artesians, it has gotten to the point to where it is leaking out of the cap and it looks like it has also fractured the concrete that the cap sits on. I would appreciate any ideas on how to fix this. I am currently running a sump pump but because of how the well was built the sump pump doesnt even kick on until the water is over the top of the cap. I am thinking that if I can't repair the cap that this spring I will run a drain pipe from the pump house out to my lower field and then just allow it to gravity drain. Thanks for your help.
  2. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    Flowing well!
    Are you using this well? If you aren't and don't plan to in the future you may want to plug it.
    However if you are using the well you may want to divert the excess water outside the pump house.
    This raises some more questions. Does the well have a water resistant well cover (no water lines out the top) or does it have a Sanitary Well Seal (pipe or pipes and wires coming out through it).
    I suspect it's a Sanitary Well Seal. If this is the case the seal may be leaking from the artesian pressure. There is usually a vent plug (1/4" or 1/2" pipe plug). You may be able to remove the vent plug and install fittings and pipe to divert it outside the pump house.
Similar Threads: Overflowing Artesian
Pumps and Tanks Well Forum & Blog. Water is life. Sand overflowing in drilled well Oct 20, 2011
Pumps and Tanks Well Forum & Blog. Water is life. How to chlorinate an overflowing well.... Jul 17, 2010
Pumps and Tanks Well Forum & Blog. Water is life. Well overflowing around pipe May 4, 2009
Pumps and Tanks Well Forum & Blog. Water is life. Overflowing well May 25, 2006
Pumps and Tanks Well Forum & Blog. Water is life. Artesian 4 " well failing attempting repair NEED HELP Oct 13, 2015
