Overflow gasket wrong taper for old tub
Discussion in 'Shower & Bathtub Forum & Blog' started by waltsyd, Jan 1, 2013.
  1. waltsyd
    waltsyd New Member
    Nov 29, 2012
    Three Rivers, CA
    The old clawfoot I'm installing needs an 8 degree tapered gasket for the overflow to be vertical. All I have found so far are 11 degree gaskets. I've only seen the harder rubber ones; would the sponge rubber one deform enough for me to go vertical the extra three degrees? Any ideas where I can find a specially tapered gasket if the sponge one doesn't work?
  2. waltsyd
    waltsyd New Member
    Nov 29, 2012
    Three Rivers, CA
    I tried it with a flat washer and it works! Doh! The overflow fitting is already at a little bit of a taper, just the right amount.
Similar Threads: Overflow gasket
Shower & Bathtub Forum & Blog Bath Overflow drain Gasket issue Jan 7, 2013
Shower & Bathtub Forum & Blog question about possible worn gasket behind bathtub overflow plate May 9, 2010
Shower & Bathtub Forum & Blog Leak from overflow gasket on tub drain Nov 21, 2009
Shower & Bathtub Forum & Blog drain and overflow rubber gasket problems.. Mar 21, 2008
Shower & Bathtub Forum & Blog overflow gasket repair Feb 14, 2008
