Overflow Cut Off Switch
DYIWeller
Santa Fe, NM
Need advice on setting up some type of Cut Off Switch in the mechanical room of home.
The cut off switch, would trigger the well pump to turn off, when some type of water sensor detects water in mechanical room.
The water heater, and water pressure tank, and other water lines are located in Mechanical room.
There is currently a drain in the center this room.
It appears some sort of power relay and water sensor would work.
Does anyone know where to buy or how to do this?
