Over Drawing my Point?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by mrjaybov, May 1, 2009.
  1. mrjaybov
    mrjaybov New Member
    Apr 29, 2009
    I have a 2hp pump connected to my 2 inch well which is about 22ft down. My pressure keeps going up and down, I'm thinking lack of water. I have plenty of water in the point but not sure it can "refresh" itself fast enough for a 2hp pump. I have a extra 1/2 hp pump, could I hook that up to my 2 inch well with a 1 1/4 output or is it to small for that size well.to run a sprinking system? 7 zones, 5 heads per zone.
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    If this is a screened well, a two horse centrifugal is way too much pump. You would be lucky to get 20 gpm from a two inch screened well. A 1/2hp jet pump will produce around 10 gpm.
    bob...
  4. mrjaybov
    mrjaybov New Member
    Apr 29, 2009
    What size pump would you recommend. I have an average of 5 heads per zone. Can a 1/2 hp pull enough water through a 2 inch well. Probably 5-6 feet of water in the pipe.
    All I have is a 2 inch galv pipe hooked to a 2 inch point driven in the ground. Is that a "screened well" as you mentioned
  5. speedbump
    Jul 15, 2005
    Riverview, Fl.
    Since you have this 2hp hooked to the well already and it's capable of pumping 50 gallons plus per minute, do a test and see how many gpm this well can do?
    bob...
Similar Threads: Drawing Point
Pumps and Tanks Well Forum & Blog. Water is life. Shallow well is drawing sand Oct 13, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Overdrawing a shallow well? Dec 11, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Jet Pump drawing air Oct 4, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Not drawing any water? Dec 15, 2009
Pumps and Tanks Well Forum & Blog. Water is life. Pump drawing high amps; what to do? Jun 30, 2009
