Oven outlet next to Bathroom Plumbing
Discussion in 'Electrical Forum discussion & Blog' started by Steven Palmisano, Apr 28, 2009.
  1. Steven Palmisano
    Steven Palmisano New Member
    Jan 21, 2007
    Florida
    First, I'd like to thank everyone on this site and for helping me with so many things, you all have saved me a ton of cash. Thanks!
    Here's my question - I am remodeling my bathroom. I opened the wall to move the water pipes/drain down a couple of feet so the vanity fits. However if I do that the water pipes will be right next to a 220V oven outlet as the kitchen share a common wall with the bathroom. There is a metal box in the wall with the 220 line going to it. Is this a problem? I fear a leak, shock and you know the rest. What should I do?
    Thanks again
  2. jadnashua
    I don't think it is a problem. I would not want the metal box touching the pipes, but as long as there is some space between them you should be okay. See what the pros have to say, but I don't think this is an issue.
  4. jbfan74
    jbfan74 Electrical Contractor
    Jun 14, 2007
    Newnan, GA
    Not an issue at all.
  5. Steven Palmisano
    Jan 21, 2007
    Florida
    Pirate, I appreciate your answer and will go with it...but let me ask you, you sure I shouldn't worry about water hitting this box, maybe a leak...maybe just paranoid (Ozzie)
    Steve
  6. Billy_Bob
    Billy_Bob In the Trades
    Apr 2, 2008
    Pure water does not conduct electricity. But water with minerals and especially salt does conduct electricity.
    The metal electrical box for the range should be grounded. This would protect you. And metal plumbing pipes should be grounded as well and would protect you. Plastic pipes would not conduct electricity.
    If you are not sure if these things are properly grounded, and that your electrical system has a proper ground, you could call an electrician to check it to be sure.
    Other that that, this is YOUR house, so do what makes you feel safe. You could always run a few beads of caulking around the metal box and stick plastic to the caulking (build a little waterproof roof over it). Then if any water leaked, it would run to the sides of the box and down.
    I don't know if caulking conducts electricity or not. But to be safe, turn off the electricity to your house before applying caulking to the metal box in case any drips through a hole into the box.
    I've done this to electrical boxes which face the outside in a wall before. I caulk all around any holes and where the wire goes through. This is more of a "seal the air leaks" and "energy saving" thing though. Air flowing through outside walls into the house can increase a heating bill. And outlets in walls are one air route along with pipes, etc.
  7. hj
    leak
    If you have a leak, then the electrical box will be the least of your problems because it will short out and trip the breaker, but you will still have to fix the leak.
  8. Steven Palmisano
    Jan 21, 2007
    Florida
    Thanks everyone....God Bless you and be safe!
Similar Threads: Oven outlet
Electrical Forum discussion & Blog Can I wire in an oven to this sub panel? Tuesday at 11:20 AM
Electrical Forum discussion & Blog Dual oven with 6 wires Nov 10, 2016
Electrical Forum discussion & Blog Wiring a double oven. Sep 23, 2015
Electrical Forum discussion & Blog Kitchen lights dim when oven heats Oct 23, 2014
Electrical Forum discussion & Blog Oven neutral or not Jul 3, 2014
