Oven gas line
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rssahlman, May 12, 2011.
  1. rssahlman
    rssahlman New Member
    Jun 18, 2009
    Cedar Knolls, NJ
    I'm about to remodel kitchen and with the new range (gas) I need to move the gas line into the wall. I have access below (basement) to the gas line but to make for an easier install am I allowed to use flexible gas pipe to go from basement into wall outlet box (the distance is just a foot or less)? The shut off is in basement so I plan on adding a shutoff inside the wall outlet box as well.
    Thanks
    Rick
  2. bsperr
    bsperr Member
    Apr 23, 2008
    Athens, GA
    If you're going to use CSST, I would use one of the supply boxes designed for the system like this one. They have a built-in auto-flare fitting with a valve.
  4. jimbo
    jimbo Plumber
    You must NOT use the basic flexible gas connectors inside the wall, or between floors. You can use CSST, but until recently at least, you could not buy that if you were not a licensed plumber. Takes some special skills to put it together.
  5. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Unless you took the course for Trac pipe you can not install it.Pro only .
  6. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Both HDepot and Lowes sell CSST here. Special skills?
  7. rssahlman
    Jun 18, 2009
    Cedar Knolls, NJ
    I was going to use that exact control box that bsperr has shown and thought I would use one of the connectors (stainless steel flexible gas connector) that i found from plumbing supply (I can't seem to post the url)
    specifically one with 3/4 mips x 3/4 fips 12" long ...the female connector to replace the pipe coming from the t-connector below the floor and the male connector attaching to the valve in the box. Can someone tell me if this would be appropriate!
  8. hj
    If you read the tag on the supply pipe, it should say that it CANNOT be used inside a wall, and it can also NOT be used to go through a wall or floor. It must be completely visible with both connections in the same room. Home Depot and Lowes apparently do not care if customers burn their houses down using CSST improperly. Their defense may be that they ONLY sell things they cannot be responsible for how they are used.
  9. jimbo
    jimbo Plumber
    What you have is a flexible gas connector. You CANNOT put that inside a wall, through a wall, or through the floor. THIS is flexible gas PIPE: http://www.tracpipe.com/trac/technical/111743_Omega_Flex.pdf
Similar Threads: Oven line
Plumbing Forum, Professional & DIY Advice Propane leak to Oven Jun 13, 2014
Plumbing Forum, Professional & DIY Advice Coventional instal vs. macerator Sep 25, 2009
Plumbing Forum, Professional & DIY Advice Problem with Spirovent Feb 6, 2008
Plumbing Forum, Professional & DIY Advice nova novent and sewer gas smell Feb 21, 2006
Plumbing Forum, Professional & DIY Advice Gaggenau steam oven Feb 27, 2005
