Oven Blew Up at Connector with Element
Discussion in 'Electrical Forum discussion & Blog' started by cynthiap, Nov 24, 2008.
  1. cynthiap
    cynthiap New Member
    Nov 24, 2008
    Hi there,
    I don't know if this a question that can be answered here or not, but thought I'd give it a try.
    The heating element in my Peerless Premier Oven stopped working on Friday night. It had no heat.
    Last night before I took it out to take it downtown today and get another one I thought I would make sure everything was connected tightly and give it another try. So I pulled out the connectors and made it sure it was connected properly and turned the oven back on. There was no heat and I was about to turn it off when suddenly it blew up inside the oven. The element itself did not blow up, but it blew up where the element connects to the connector. Sparks blew everywhere, a big puff of smoke, the electricity flickered off and back on in the house and it smelled a little like firecrackers.
    It was really scary and we were really lucky both my son and I had literally just pulled our heads out of the oven when it blew up. If it had been seconds before our face would have been burnt.
    Now in the hole where the connector and it's wire come into the oven there is another smaller hole that got burnt into the metal of the oven and it is all black like there was a fire in there.
    So my question is this. Was this the result of the element going bad, or was something in the wiring and the connector causing the element to go bad? I've replaced elements several times in my life, but I don't know if it's safe to put in a new element or not.
    I've had elements go bad before and usually there is a visible break in the element itself. But there is no break in it this time.
    Would appreciate any words of wisdom if anyone has any.
    Thanks
    Cynthia:)
  2. jadnashua
    It sounds like the wiring going to the element connector has shorted to the frame of the oven. I don't think a new element would resolve this. The wire is probably burned off and hanging there, and could energize the chassis of the oven. If the breaker didn't trip, turn it off. The harness and connector may need to be replaced. You can't solder those connections since the heat would likely melt it and compromise the connection, so unless you can get a new harness and bolt it in, you probably can't fix it. Then again, I'm not an oven repairman, so take this with a grain of salt...
  4. Igor
    Igor New Member
    Dec 2, 2007
    Former Motorhome Electrician
    Oregon
    It's possible that the failure is right at the end of the wire where it connects to the element. If you're lucky, there may be enough slack in the wire to cut off the damaged end of the wire and crimp on a new connector. The usual Faston-type connector that you can buy at a hardware store won't last very long in this application--be sure to get a high-temperature connector, whcih you should be able to find at an appliance parts store. Be sure to inspect the wire and make sure that there's no damage to the insulation that could short to the frame of the oven. If you're not comfortable with this kind of work, it would be a good idea to get a professional appliance repairman to do the job.
  5. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    No better advice could be given than the statement above.
  6. Billy_Bob
    Billy_Bob In the Trades
    Apr 2, 2008
    Also be aware that ranges use special high heat rated wire. This stuff costs nearly $3.00 a foot and can be purchased at appliance stores. Not sold at the big box stores (in my area).
    I've seen older ranges which did not have the "new" high heat wire and the insulation had "shrunk" back a few inches in many places exposing bare wire. The thing to do for this is re-wire with new high heat range wire.
  7. cynthiap
    cynthiap New Member
    Nov 24, 2008
    Thanks everyone.
    I called the manufacturer of the stove to order a new element and talked with them about what happened. He told me that I touched metal to metal and created an arc. He said all should be fine after I put in the new element. Unless if it doesn't work then I may need to replace connector and thermostat. So problem solved.
    I appreciate your taking time to offer you thoughts.
    Happy Thanksgiving!
  8. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    Things are not adding up here unless you had been poking or moving something just before the arc. Yes, your element is likely bad, but it is now very possible you need something more than just a new element. You really should get a technician involved to be sure your wiring and connections truly are still good.
  9. Bill Arden
    Bill Arden Computer Programmer
    Sep 30, 2006
    computer programmer
    MN, USA
    When this happened to me, I had to replace the thermostat switch as well since the high current damaged it.
    In my case the element wasn't removable, but the insulator broke.
Similar Threads: Oven Blew
Electrical Forum discussion & Blog Can I wire in an oven to this sub panel? Tuesday at 11:20 AM
Electrical Forum discussion & Blog Dual oven with 6 wires Nov 10, 2016
Electrical Forum discussion & Blog Wiring a double oven. Sep 23, 2015
Electrical Forum discussion & Blog Kitchen lights dim when oven heats Oct 23, 2014
Electrical Forum discussion & Blog Oven neutral or not Jul 3, 2014
