Hey all,
I'm remodeling my master bathroom and am trying to figure out good plumbing locations. In my research, I haven't been able to find a good answer to this question...
I know people really try to avoid putting plumbing in an outside wall, understandably. One of the walls in the bathroom has an unfinished attic on the other side of the wall, and I'm not sure if I should avoid plumbing in that wall. There is blown in insulation on the floor of the attic, and there is rigid foam insulation along the wall in question. I could potentially also add additional insulation between any plumbing and the rigid foam, although I might only have an inch or two of space once plumbing is in.
So, should I be worried about plumbing in this wall? I live in Virginia, just outside DC. We get snow and freezing temperatures in the winter, occasionally with temperatures in the teens or single digits. I know this wall isn't exactly external with the attic on the other side. And even though the attic can get cold, it still is getting some residual heat from the house.
Thanks,
Tyler
Thanks,
Tyler
