Outside switches
Discussion in 'Electrical Forum discussion & Blog' started by toolguy504, Jul 19, 2009.
  1. toolguy504
    toolguy504 DIY Junior Member
    Dec 21, 2007
    Chalmette, Louisiana
    I have a covered porch and will be installing two fans on it. I would really like to put the switches on the exterrior side of the wall by the door rather then on the interrior side. Can I use the same boxes and switches as you would on the inside or do I need to put some type of exterrior weatherproof boxes and switches. Thanks. Earl
  2. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    If the box is surface mounted it must be a weatherproof type.
    Cover plates too.
    Switches are the same.
Similar Threads: Outside switches
Electrical Forum discussion & Blog Correct type of wire to connect to A/C outside unit. Mar 2, 2014
Electrical Forum discussion & Blog 3-way switching, outside damp location, off of a GFCI Dec 5, 2013
Electrical Forum discussion & Blog Connecting Outside Generator to Transfer Switch Nov 6, 2011
Electrical Forum discussion & Blog What box is best for Outside Wall Light Fixture in Existing T-111 to cut in? Jun 26, 2010
Electrical Forum discussion & Blog Is it wise to install service panel on outside of house? Nov 12, 2009
