outside spot light
Discussion in 'Electrical Forum discussion & Blog' started by Barry J, Nov 18, 2008.
  1. Barry J
    Barry J Member
    Mar 2, 2007
    Mass
    I have an outside spot light shining on my driveway with a sensor set-up. It's been there probably 9-10 years, so it's the old style.
    I would like to replace it, cause it hasn't worked well anyway, and I would like to get something more modern and efficient.
    Any suggestions on what's out there nowadays
    Thanks
    Barry
  2. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    This is the 13 watt compact fluorescent fixture we have been installing for years. Focus brand.
    It's pretty stealthy but they make a smaller one now. Put it on a photo cell and it will cost about 20 cents a month to operate, dusk to dawn and the lamps last for years.
    [​IMG]
  4. Barry J
    Barry J Member
    Mar 2, 2007
    Mass
    Thanks great info...If I use a photo cell, won't it come on at night??? That's not my purpose. I wanted one with a sensor for movement and have the option to switch it on when needed. Not for dusk to dawn.
    Does "focus" make one for that??
    Thanks
    Barry
  5. jimbo
    jimbo Plumber
    You can get a photocell adapter for any fixture. Fluorescent bulbs are not really fond of frequent switching like with a photocell. Might have short bulb life, or flickering.
    If you are operating only on a motion sensor, then energy consumption is not necessarily a deal breaker, and why not just a halogen flood?
  6. Barry J
    Barry J Member
    Mar 2, 2007
    Mass
    Halogen flood is what I have now...and like you said, i guess efficency not a problem, cause the only time it would go off if something moves in my driveway or I'm working out there.
    I guess my question is ...that mine is old and never really works well. I'm looking for a motion sensored spot light that has a good sensor, and won't go off cause of rain and will be able to be turned on on demand for outside driveway work in the dark
  7. jadnashua
    Most of those I've seen are not made here, so QA/QC may be an issue. Some claim to have multiple zones, and the motion must logically cross them (i.e., not jump around) for it to decide it is something real. Since they are infrared triggered, I'm surprised that rain would do it. Where do you live? I suppose really warm rain might show enough of a temperature difference, but that surprises me. I've not done a survey on anything currently available...good luck in your research.
    CFL bulbs often won't work with add-on motion detectors. If you want to go with that type of bulb, you probably need to find one specifically designed for it, or possibly just changing the bulb when it dies could prevent it from working. Also, check carefully on the required orientation and temperature operating range of the bulb since some CFL shouldn't be used base up and won't work in severe cold (not universal, but common).
Similar Threads: outside spot
Electrical Forum discussion & Blog Correct type of wire to connect to A/C outside unit. Mar 2, 2014
Electrical Forum discussion & Blog 3-way switching, outside damp location, off of a GFCI Dec 5, 2013
Electrical Forum discussion & Blog Connecting Outside Generator to Transfer Switch Nov 6, 2011
Electrical Forum discussion & Blog What box is best for Outside Wall Light Fixture in Existing T-111 to cut in? Jun 26, 2010
Electrical Forum discussion & Blog Is it wise to install service panel on outside of house? Nov 12, 2009
